Where To Wire In To Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 02-27-2008, 08:52 AM   #1
Where to wire in to circuit
I have a 14-3 wire running from my breaker box to a light fixture. I then have a 14-2 running to my switch (wired as a switch loop). I want to run several outlets in the room and am wondering where to wire into the current circuit.
Thanks for your help/suggestions.
Brack
brackh is offline   Reply With Quote
Old 02-27-2008, 09:09 AM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Brack
To continue that circuit to receptacle outlets, you would connect in the light fixture box. That is where the neutral wire is.
jrclen is offline   Reply With Quote
Old 02-27-2008, 10:03 AM   #3
So how do I wire in to the light for the receptacles and still have room to wire into the switch?
Old 02-27-2008, 02:26 PM   #4
Rewards Points: 1,164
I highly doubt you have a 14/3 from the breaker box to the fixture, and then a 14/2 to a switch, and that is all there is to the circuit. Are you sure you cdon't have that backwards?
LawnGuyLandSparky is offline   Reply With Quote
Old 02-27-2008, 07:08 PM   #5
jrclen's Avatar
Rewards Points: 514
What size j box is present at the light? Using a common 4" round x 2 1/8 deep box allows 10 #14 conductors for box fill. Is this what you are referring to?
You do have a junction box at the fixture, right?
Old 02-28-2008, 06:04 AM   #6
Hire a qualified electrician...someone is going to get hurt.
NAIL is offline   Reply With Quote
Using 14/2 wire on 20 amp circuit mohairy Electrical 1 12-29-2007 06:26 AM
Can you wire a 3-way circuit with 2 wire + ground mnyman2003 Electrical 8 12-04-2007 08:23 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
HELP with Arc Fault Circuit Interruptors! samf Electrical 3 11-24-2006 10:56 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
