Where To Run The Wires ? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2012, 10:33 PM   #1
Rewards Points: 216
where to run the wires ?
hello, gents.
i am going to be wiring a room to its own new circuit. it is a wiring hodge podge right now. anyway. i don't know how i should run the new wiring for the outlets around the 2 doors in have it the room. in other words = outlets on 2 walls. then i have to run to the outlets on the other 2 walls. but i have to go past 2 doors. i have a junction box in the basement that will be feeding the whole bedroom.
i know this is easy. but i just can't decide on the right way to do it
thanx
Fix'n it is offline   Reply With Quote
Old 07-17-2012, 11:49 PM   #2
Master Electrician
Either go into the ceiling or into basement and come back up. You can run the wire wherever you want except for though the door :D
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew79 For This Useful Post:
Fix'n it (07-18-2012), PaliBob (07-18-2012)
Old 07-18-2012, 08:41 PM   #3
Rewards Points: 216
ok. going down, i'm trying to not do that. i can go through the attic. but by what you are saying, i can go over the doors ?
the walls are opened up.
Old 07-18-2012, 09:12 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Go from point 'A' to 'B' it's that simple.
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 07-18-2012, 09:19 PM   #5
Rewards Points: 216
got it. thanx
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 09:00 PM
if there are red white green and black wires coming out of your walls like everywhere cray331 Electrical 3 01-17-2011 01:56 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 08:07 PM
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
