Old 10-21-2007, 10:15 PM   #1
Where to run the line...opinion wanted
Question: If somebody wants to run a new line to an attic (no pre-existing line exists), would it be better to run a new line across a basement to an opposite wall and up to the attic OR make a short run from the breaker box to and up the stack pipe into the attic?
The way it will be done (as advised now) will be 14-2 across the basement, up the wall to the attic and split from there.
The stack pipe is only 5 feet from the box and I honestly think a shorter run, given the 14-2, is a better and safer bet.
Any opinions?
Scottz is offline   Reply With Quote
Old 10-21-2007, 10:58 PM   #2
jproffer's Avatar
What do you mean "up a stack pipe"? An abandoned waste pipe? Up the outside of an active waste pipe? Abandoned plumbing, while handy as he**, isn't really the best (by best I mean most compliant) way of getting a wire from A to B. Going to the wall can't amount to that much more wire, and if this is going to be inspected you may get gigged for the pipe=conduit method, because it doesn't.
If you mean outside the pipe, I don't see why not.
jproffer is offline   Reply With Quote
Old 10-22-2007, 12:51 PM   #3
J. V.'s Avatar
I always take the shortest path on concealed NM. What is a stack. I hope it is not a smoke stack.
Old 10-22-2007, 12:55 PM   #4
Probably the main Plumbing drain stack?
mdlbldrmatt135 is offline   Reply With Quote
Old 10-22-2007, 06:41 PM   #5
joed's Avatar
If you are talking about running the cable up the space beside the plumbing stack that is not a problem.
ac suction line placement? nimbenja HVAC 8 10-28-2009 06:43 AM
Condensate Line schott HVAC 17 06-02-2008 04:16 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 08:51 AM
Installing exterior faucet to washer line? skellies Plumbing 3 06-18-2006 09:19 PM
