Where To Put The ECG On A Light Fixture Socket That Does Not Have A Ground Terminal. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 06:48 PM   #1
Where to put the ECG on a light fixture socket that does not have a ground terminal.
Hello,
I have started a new hobby of refurbishing antique light fixtures. I am currently working with a three-wire, cloth-covered pendant wire (black, white, green), but the new socket (a vintage replica) does not have a place to connect the ECG - at least not one I can identify. So, I need to know where to put the ECG on the socket itself.
I'm trying to get a picture added of the socket in hopes someone can explain where I should put the ECG, but am getting an error message, but I'll keep trying - Got it (file sizes...).
Thank you,
Kim
Where to put the ECG on a light fixture socket that does not have a ground terminal.-20120826_173141.jpg   Where to put the ECG on a light fixture socket that does not have a ground terminal.-20120826_173124.jpg
Kim H is offline   Reply With Quote
Old 08-27-2012, 12:12 PM   #2
joed's Avatar
Rewards Points: 12,000
You don't use it or you connect it to the metal frame of the fixture. It does not connect to the socket.
The Following User Says Thank You to joed For This Useful Post:
Kim H (08-28-2012)
Old 08-28-2012, 09:28 AM   #3
Thank you, I appreciate it.
Kim
Tags
cloth cord , ground wire , light fixture , no-ground socket , refurbish
Thermostatically controlled light socket????? beebiz Electrical 28 11-26-2011 04:45 PM
Grounding a light fixture with no ground wire? daniel123 Electrical 2 11-07-2011 08:21 PM
New light fixture problem debradough Electrical 7 09-19-2011 11:23 AM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Light Socket Won't Hold Light Bulb colhollywood Electrical 3 08-16-2008 09:28 AM
