Where Is The Power Switch??? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 10:01 PM   #1
Where is the power switch???
I have currently lived at my home for 3 years now and my garage light has been on 24/7 because I don't know where the switch is, a friend of mine is an electrician and he had no idea. I'm tired if replacing bulbs and I'm starting to feel guilty about the energy I've been wasting. Help
cochise7969 is offline   Reply With Quote
Old 08-08-2009, 10:13 PM   #2
Electrical Contractor
kbsparky's Avatar
Replace that fixture with a motion-sensor type. Then it will only light when there is someone in the garage -- saving lots of energy usage.
-KB
Old 08-08-2009, 10:39 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Keep him as a friend and fire him as an electrician....
If your garage was like mine when I was working it's totally understandable not being able to find the switch. However it has to be there somewhere or if it is an outside light it may be a motion sensor light failed 'on' and wired constant hot with no switch. Only the breaker will turn power off to it.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-08-2009, 10:47 PM   #4
dSilanskas's Avatar
If your talking about a light inside your garage perhaps they tried to cheap out and installed a pull chain?
dSilanskas is offline   Reply With Quote
Old 08-09-2009, 05:01 AM   #5
biggles's Avatar
mount a light switch in a utility size box,and run a lenght of romex/bx up to the light and break the BLACK wire
Old 08-09-2009, 07:05 AM   #6
Rewards Points: 1,492
A motion sensor light for indoor use can be very annoying when it turns off when you are in the middle of some quiet activity.
For an outdoor light is is okay to leave it on all night. Use a compact fluorescent lamp if it doesn't dim down too much in winter.
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
no power to light switch diople Electrical 6 05-16-2009 01:40 PM
power from outlet to switch lincoln85 Electrical 2 10-09-2008 12:04 PM
Adding a Switch and jump power Bull-37 Electrical 9 01-10-2008 05:45 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
