Where To Place Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 05:30 PM   #1
where to place recessed lights
remodeling....two small rooms 13 x 11 into one big room 13 x 23...load bearing wall removed...14" beam placed.....I'd like to use 12 total recessed lights, what's the best placement? Thanks for your help
drobert438 is offline   Reply With Quote
Old 04-05-2010, 05:35 PM   #2
Rewards Points: 1,192
A floor plan would help us.
bobelectric is offline   Reply With Quote
Old 04-07-2010, 02:12 AM   #3
Union Electrician
goose134's Avatar
Include a ceiling height. Helps determine spacing.
goose134 is offline   Reply With Quote
Old 04-07-2010, 10:22 AM   #4
Master Electrician
depends on the size of lights. Rule of thumb is to try and keep the spacing about the same as the can...4" can 4 feet apart....5" can five feet apart. Without a floor plan this is the best I can do for you. I seriously doubt you'd need all 12 to light that space up. perhaps center four lights in the ceiling space on either side of the beam.
andrew79 is offline   Reply With Quote
Recessed Lights amd250 Off Topic 2 02-05-2010 10:32 PM
Adding new circuit for recessed lights.... DickieFL Electrical 7 11-21-2009 08:12 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 04:20 PM
what are the tricks to insulating above recessed lights? red86yota Building & Construction 8 01-29-2009 06:54 PM
Recessed lights rough in helpless handyman Electrical 2 11-19-2006 06:51 AM
