Where To Place Coax Jacks - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 12:27 AM   #1
Where to place coax jacks
I want to update a mid 60s apartment by surface mounting at least one RG6 jack in the bedrooms. I own the apartment and will resell it eventually. How many RG6 jacks would be typical for a bedroom like the one below if it were built today, and where's a good location for them? The cables will be coming in from the hallway and I think I should drill from the hallway into the bedroom closet (which I'm allowed to do) to install a jack on the wall opposite the entrance, but I'll definitely put a jack on the same wall as the entrance, so if one is enough I won't bother going through the closet.
Dorado is offline   Reply With Quote
Old 02-10-2013, 01:27 AM   #2
Rewards Points: 6,652
Usual rule of thumb is where the most convenient location that a TV may be placed, or near the telephone jack. With flatscreen hdtv sets being mounted to walls, your best bet would be to place one low, and one high up where a mount would be, along with a Cat-5e or Cat-6 and power, just in case someone wants to mount their tv on the wall. If you do not want to mount said jacks up high, you can use a pass-through conduit, that would allow someone to pull everything up inside the wall, and drop the power cord down to plug into the outlet down below.
Figure in your wiring, Telephone that is using Cat-5e/Cat-6, a extra pull for ethernet, and a coax.
Old 02-10-2013, 08:03 AM   #3
Master Electrician
Rewards Points: 3,750
Place the jacks on the wall that is likely to be opposite of the bed.
brric is offline   Reply With Quote
Old 02-10-2013, 09:08 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Not everyone will agree on where they should go. I would put them in the most convenient spot and they can always run a wire to where they want the tv. And as long as there are enough receptacles finding a place to plug in the tv should not be much of a problem.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Flex Hoses Able to be Tightened or Pressed in Place? WillJohnston Plumbing 5 03-04-2011 09:09 PM
Optimum placement of vent jacks relative to laps? mysterylectric Roofing/Siding 0 03-01-2011 02:55 AM
Where to place water hammer arrestor? scottieslg Plumbing 5 01-05-2011 01:43 PM
New toilet wont go all the way down into place ron0805 Plumbing 11 10-13-2009 12:15 PM
Running New Coax modena Home Theater 3 07-18-2007 02:18 AM
