Where Is Model # On Cutler Hammer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2008, 06:29 PM   #1
where is model # on cutler hammer
Where can I find the model number on my 1992 cutler-hammer breaker panel?
donaldbyrd is offline   Reply With Quote
Old 01-25-2008, 07:14 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Don...... there should be a specifications sheet on the inside of the panel door with that information.
Old 01-25-2008, 07:16 PM   #3
there is a specifications sheet on the inside of the cover but I do not see where it has the model number.
Old 01-25-2008, 07:21 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Don...should be there is there any numbers like BR3030L125RP or CH3040M200CU
Old 01-25-2008, 07:26 PM   #5
no nothing like that all of the stickers have 30-xxxx which I have a feeling are the part number for the sticker
Old 01-25-2008, 07:30 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Don
Let me check for a ch panel break down and see if I can find where else it might be. be back in a few.
Old 01-25-2008, 07:54 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Don
Everything I'm showing in my catalogs is showing the model number on the specifications sheet inside the door. Try searching e-bay for cutler hammer load centers and see if they show a picture of a panel like yours for auction sometimes they have close-ups of the panels. Or try the eaton cutler hammer website.
sorry I couldn't help you more.
Old 01-25-2008, 07:56 PM   #8
appreciate the help
Old 01-26-2008, 10:08 AM   #9
Rewards Points: 27
If it a 1992 Cutler-Hammer panel, it's a type CH* so the panel info is inside the panel on a sidewall of the box. Eaton (Cutler-Hammer's parent) did not buy the Westinghouse line untill a few years later, adding the favorite of hacks everywhere, the Bryant/Westinghouse type BR line...
* That panel is the last decent residental/light commercial panel left on the market, the so-called "Cadillac" panel (SQ D QO) has long gone downhill in quailty as with with their competitors.......
BTW, the color of the box and trim will be sandalwood, not gray if a C-H "Classic" panel.
Norcal is offline   Reply With Quote
Old 01-26-2008, 11:49 AM   #10
sure enough that is exactly where is was, I did not see it before because the mains are running up that side. thank you
Old 01-26-2008, 12:15 PM   #11
UAW SKILLED TRADES
Stubbie's Avatar
Ahhhhh yes the sandalwood ch panels. Consider yourself lucky Don.
Old 01-27-2008, 07:04 PM   #12
yes but now I have to decide if I should have a new 42 pole panel put in or add a sub panel near this one.
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 07:26 PM
hammer tacker/stapler Clutchcargo Building & Construction 2 09-20-2007 08:28 AM
Any advice on a good brand of air conditioner (window model) ? nubee Appliances 2 06-12-2007 03:24 PM
Broan Exhaust Fan Not Vented to Outside? Is there a model where this is not required? House_Amuck Remodeling 10 04-23-2007 08:12 PM
Water Hammer ffgus Plumbing 3 12-31-2006 10:19 AM
