Where Is The Main Breaker! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-26-2013, 11:56 PM   #1
hohadcr's Avatar
Rewards Points: 306
Where is the main breaker!
Hi,
I have a simens breaker box. like this one:
http://www.renodepot.com/fr/sous-pan...rique-22635052
I dealt with DQ breaker boxes, where I can turn off the main breaker of 100A or 200A, before unscrewing the breaker box surface cover.
On the Simens breaker box, I can't find the main breaker. Do I need to unscrew the cover first to access the main breaker?
I need to shut the main breaker off to add some more breakers to the panel.
hohadcr is offline   Reply With Quote
Old 03-27-2013, 12:19 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by hohadcr View Post
Hi,
I did look at your link and you are lucky that I can read in French without issue.
Now the question of " disjoncteur principal " aka main breaker is that below the meter socket.
If you do not have the Disjoncter principal at all this will get tricky to deal so let us know asap.
Merci,
Marc
Old 03-27-2013, 12:20 AM   #3
Rewards Points: 12,856
Not sure why you would be shutting off the main just to remove a cover.
You may be looking at a sub panel that's why there no big main breaker.
Often times a sub will be fed into a double pole breaker on the side of the panel. It will be the one with the highest amperage marked on it.
Old 03-27-2013, 04:17 AM   #4
Electrical Contractor
kbsparky's Avatar
The panel from the link is a "main lug" type. No main breaker included.
-KB
Old 03-27-2013, 07:24 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Hi,
Show us a picture of YOUR actual panel.
Also, what is a "DQ" panel? Never heard of it.
Old 03-27-2013, 07:59 AM   #6
Rewards Points: 720
Yummm, Dairy Queen panel. Argggggh. (picture Homer Simpson).
Mark
busman is offline   Reply With Quote
The Following User Says Thank You to busman For This Useful Post:
Speedy Petey (03-27-2013)
Old 03-27-2013, 08:03 AM   #7
hohadcr's Avatar
Rewards Points: 306
Thanks, will go look for the main breaker where the main lines come in.
Old 03-27-2013, 12:00 PM   #8
Some main electrical panels have no main breaker!
Note you have the option of calling the electric company and having them remove the electric meter so you can then work safely.
Billy_Bob is offline   Reply With Quote
Old 03-27-2013, 12:15 PM   #9
Rewards Points: 736
I had a panel where the main breaker was outside just below the meter (which I believe is what frenchelectrician is referring to).
TheBobmanNH is offline   Reply With Quote
main breaker tripping larsalan Electrical 12 07-17-2012 03:27 PM
running a subpanel from the main breaker on the pole. shocknawe Electrical 6 05-09-2011 10:51 AM
Main Breaker Melting rubberhead Off Topic 8 03-16-2011 08:50 PM
Remove Main Breaker from Subpanel fblankinship Electrical 5 10-28-2010 08:11 PM
Single breaker vs double pole breaker for MAIN tuckerz Electrical 11 11-16-2009 07:42 PM
