Where Is The Ground? (pics) - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2011, 11:50 AM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
Where is the ground? (pics)
Here is my panel. The entire house is wired with 1" flexible conduit and two conductors inside.
If I add or replace newer receptacles that have the ground screw, how do I wire it?
This is a fifties home, not sure how old the panel, fuses and breakers are.
Next step to make things safe, is to move the service to a new location (recommend by DWP) and upgrade the panel.
picflight is offline   Reply With Quote
Old 09-01-2011, 12:41 PM   #2
Rewards Points: 6,652
The armor is your ground.
Old 09-01-2011, 12:47 PM   #3
Busy DIYer
picflight's Avatar
Rewards Points: 150
So, if I extend a circuit with NM, the new receptacle that comes with the green ground screw and can be routed to and screwed to the metal box? The metal conduit will carry the ground further on to a termination point in the panel?
Old 09-01-2011, 12:52 PM   #4
You will have to check with your city hall, to see if they allow the use of Romex first. And what is with the two Red wires taped in the box.
Old 09-01-2011, 01:03 PM   #5
Busy DIYer
picflight's Avatar
Rewards Points: 150
The main fuse was blown, I had an electrician replace it and in doing so he disconnected the electric oven, he discovered a possible short in the run to the oven. He suspected that the wire to the oven was probably damaged while running the wire. I think those two Red wires are from the oven breaker.
Old 09-01-2011, 02:38 PM   #6
An electrician did that? Did he have any other recommendations to go along with it?
bigdaddyII is offline   Reply With Quote
Old 09-01-2011, 02:53 PM   #7
Probably more like Handyman.
The Following User Says Thank You to gregzoll For This Useful Post:
Code05 (09-01-2011)
Old 09-01-2011, 04:25 PM   #8
Busy DIYer
picflight's Avatar
Rewards Points: 150
I think the electrician did that, I do not recall what he did in the panel even though I was watching him.
Should wire nuts be on the ends there instead of the electrical tape?
Old 09-01-2011, 04:47 PM   #9
A splice shouldnt be there period. If that is what was causing the short the circuit should have been changed. There is no telling how many other melted spots like that are behind the walls etc.
Old 09-01-2011, 04:56 PM   #10
bigdaddy, splices are allowed inside of panels, just that they have to be properly terminated. That means either fold the ends over, and use heat shrink to hold the end, or use wire nuts over the ends.
Old 09-01-2011, 08:23 PM   #11
Busy DIYer
picflight's Avatar
Rewards Points: 150
Yes, move the service to the other end of the house, upgrade to 200A and tie into existing wiring via race-ways running through the crawl space. The service is aerial.
Old 09-01-2011, 08:38 PM   #12
Ouch. Good luck man. Im looking at a complete rewire and bringing house up to codes in the next year or so.
Old 09-02-2011, 03:29 PM   #13
Electrical Contractor
kbsparky's Avatar
WOw! Wadsworth breakers! You don't see many of those around these days ...
-KB
Tags
panel upgrade
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 05:10 PM
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 03:05 PM
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 08:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
