Old 12-16-2012, 06:39 PM   #1
Question
Where to find odd breaker
My friend's house has a workshop in the back with an 800 amp 120/208 volt service (used to be a wood shop). I am trying to add a circuit for him and cannot find the breaker. The panel is a cutler hammer Pow-r-line and says to only use type BAB breakers. Home depot does not carry these and neither does lowes. Where should I get the 3-phase 95 amp breaker he is looking for?
neo565 is offline   Reply With Quote
Old 12-16-2012, 06:53 PM   #2
I just Binged your info and several hundred sites came up that sell them.
If you went to a real electrical supply in your area they may have them.
Never heard of a 95 amp breaker, may have to go with 100. Depends on what the load calls for.
Old 12-16-2012, 07:06 PM   #3
Licensed Electrician
k_buz's Avatar
BAB breakers are very common. I personally have installed literally 100's this year.
Location...Location...Location
Changing Main Breaker box (or is it Main Lug box?)- pyheme Electrical 7 09-12-2012 12:29 AM
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 08:27 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 11:28 AM
Extending wire from meter box proge Electrical 11 08-13-2009 07:30 PM
cannot find the right breaker pat72 Electrical 11 08-08-2008 01:26 AM
