Where To Find Insulators - Electrical - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 03:09 PM   #1
seansy59's Avatar
Rewards Points: 258
Where to find Insulators
I have a small "utility" service running out to woods behind my house, just for a few items.
-Speakers mounted on trees
-12volt lighting system
I got a few actual high voltage insualtors that screw onto the trees, and I run the speaker wire and low voltage lighting wire through these. It goes through a bike trail, so I keep it way up high, and out of sight. I know its overkill, but it holds them nicely, while keeping a "proffessional" look.
Recently, a storm knocked down 2 of these insulators, along with the wires, and the insulators broke. I am looking for 2 new (or used) ones to repair my problem. Where can I find a few of these? The ones I had I found on the side of the road near a telephone pole, just sitting in a pile.
Here is what I have, I have 9 of these, but I need 2 new ones.
seansy59 is offline   Reply With Quote
Old 10-16-2011, 03:51 PM   #2
Rewards Points: 77
How about something like this, for electric fences.
http://www.tractorsupply.com/electri...-white-3600663
daveplot is offline   Reply With Quote
The Following User Says Thank You to daveplot For This Useful Post:
seansy59 (10-16-2011)
Old 10-16-2011, 04:29 PM   #3
seansy59's Avatar
Rewards Points: 258
WOW! I never though of that. They look exactly like mine. Since I'm not dealing with "real" voltage, this is perfect! Many thanks!
Old 10-16-2011, 04:50 PM   #4
Electrical Contractor
kbsparky's Avatar
They got `em at the home-horror stores as well
-KB
Old 10-16-2011, 05:29 PM   #5
Rewards Points: 6,652
seansy59, that is because they are the same thing.
Old 10-16-2011, 05:32 PM   #6
seansy59's Avatar
Rewards Points: 258
So the "high voltage" power line ones are the same as the electric fence ones. Because the ones I have were from an actual telephone pole.
Not that it really matters for my small use, but, just out of curiousity.
Old 10-16-2011, 05:38 PM   #7
Code05's Avatar
Rewards Points: 1,104
If your voltage is not real, what is it?
Code05 is offline   Reply With Quote
Old 10-16-2011, 07:11 PM   #8
It is imaginary. You know, only the stuff that wizards and witchery can create. I always wondered why my lights come on, when I flip the switch, the tv is able to run. It is neat how protons & electrons are able to flow along copper wiring.
Old 10-17-2011, 02:36 AM   #9
Semi-Pro Electro-Geek
Rewards Points: 2,922
The ones in your picture are not for high voltage (which is actually referred to as "medium voltage" in the utility industry). They are for secondary voltage - 120V through 480V service to buildings. You can get the same ones at Lowes and Home Depot. Electric fence insulators would work, too. Utility insulators for medium voltage (1000V-35,000V or so) are much bigger.
mpoulton is offline   Reply With Quote
Where to find a contractor? sgt_utz Building & Construction 2 09-28-2011 06:15 AM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 09:27 AM
need to find wall switch remote..does that exist? tarheelblue Electrical 7 09-05-2008 05:51 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
