Where Does 75 KW Go In A Vacant House.?? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2007, 08:34 PM   #1
Rewards Points: 150
Where does 75 KW go in a vacant house.??
Just wondering how many kw a month a couple GFIs eat up a month?? Thats the ONLY thing on in this vacant house and the meter is racking up a solid 75kw a month,,,seems like quite a bit.
I guess somehow the furnace shows degrees on the termostate,dont know how that works,,,its a brand new furnace that has barely worked yet. How much juice does it eat, not running?? (No gas service to house)(on anyway)
No frig or range even in the kitch,or plugged in.
Is this a sign of a problem?? Seems real excessive to ME??? Very small house,old and not much else there!!
justdon is offline   Reply With Quote
Old 09-08-2007, 09:22 PM   #2
Eibwen
GFI's dont eat up any power unless something is plugged in and drawing power. Try checking each breaker/circuit to see where the draw is coming from but 75kw per month for a vacant would not be unrealistic. Check the utility bill.. May not be the usage but the minimum charge.
Sammy is offline   Reply With Quote
Old 09-08-2007, 09:34 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
I think you mean Kw/Hr, NOT Kw. Or do you really mean 75,000 watts?
Speedy Petey is online now   Reply With Quote
Old 09-09-2007, 08:16 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
That would be equivalent to a 100 Watt bulb burning continuously. Is there a sump pump, attic ventilation fan or anything like that??
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 09-10-2007, 08:49 AM   #5
Once fried, twice shy.
elkangorito's Avatar
Try turning of the main switch to the premises & see if the meter is still spinning. If it stops spinning after you do this, it means that something is either switched on or you have a low insulation resistance somewhere.
An insulation resistance test can be quickly & easily done on your premises to rule this possibility out. This should be done by an electrician.
elkangorito is offline   Reply With Quote
Old 09-10-2007, 09:52 AM   #6
I have gas!
Couldn't you do this by switching the main breaker off and testing resistance between hot and neutral?
Old 09-10-2007, 09:58 AM   #7
Unfortunately not.
An insulation test, which should be carried as one of the few tests of an installation BEFORE initial energisation is done, with a thing commonly called a 'Megger' or Megohm meter. This device usually places between 250 v & 1000v on the cabling. If the cabling is good, the meter would indicate infinite Ohms resistance. A minimum safe result would be 2 Megohms. Anything less than 2 Megohms & Houston, you have a problem.
Old 09-10-2007, 01:36 PM   #8
Rewards Points: 160
Is it possible that someone is using your power without your knowledge? Like an extension cord for a construction project that has no power yet.
15,000 watts is a lot of power for an empty house, and how were you able to measure kilo watts anyway?
Old 09-10-2007, 01:47 PM   #9
Actually, the OP quoted a figure of 75 kWh (kilowatt hours) over a period of about 1 month, which is not really a lot of power. E.g. if you have an appliance that draws 2.5 kW (a good example would be an electric heater) & you use it for 2 hours, you will have used 5 kWh of energy. There are 720 hours in a 30 day month so 75 kWh's is not a lot of energy for that period.
And yes, it is possible that somebody could be tapping into your power supply but this sort of thing is usually obvious.
Old 09-10-2007, 02:09 PM   #10
Long-Time DIYer
Mike Swearingen's Avatar
Do you have an electric water heater "on" there? That would be my "usual suspect". Electric water heaters can use up to 14% of the power for an average home.
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-10-2007, 06:41 PM   #11
joed's Avatar
Rewards Points: 12,902
Could be many things such as
Garage door opener
Door bell transformer
Furnace or AC low voltage power supply
Smoke detectors?
security system
buried cable leaking current
Anything with a timer such as a water softner
Any wall wart from a radio, telelphone answer machine etc. still plugged in
Turn off breakers one at a time until the meter stops spinning.
Old 09-16-2007, 07:14 PM   #12
Master Electrician
JohnJ0906's Avatar
Could be an attic light left on, or some other light in a crawl space or other space that is rarely visited.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Re-siding house jdig Building & Construction 5 04-10-2007 09:15 AM
Will my house make my kids sick??? jokrupinski General DIY Discussions 18 09-29-2006 04:05 AM
