Where Do I Mount The Grounding Screw? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-04-2007, 11:30 AM   #1
Where do I mount the grounding screw?
Where do I mount the grounding screw on a 2' fluorescent lighting fixture?
Justin860 is offline   Reply With Quote
Old 03-04-2007, 12:00 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
There should be a green screw in the fixture already. If not, then there should be a threaded hole for a 10/32 grounding screw.
Old 03-04-2007, 12:09 PM   #3
theres a green screw and a little nut to go with it but there is not a spot to put it in. there were like 3 holes that dont look like they were for a screw but i put the grounding screw in there anyway, hope the place doesnt burn down : ( is there anything special about where the grounding screw should be mounted or it can go anywhere?
Old 03-04-2007, 12:58 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
Most fluorescents have a small unthreaded hole with two "bumps" next to it. This is where the supplied ground screw goes.
Old 03-04-2007, 06:17 PM   #5
Justin, take a pill. no need to make multiple threads with the same question.
We do apologize for the fact that no one is sittning about waiting for you to make a post so that we can answer. But, If you are patient, someone will get to you as soon as we see your questions.
Master Electrician
jwhite is offline   Reply With Quote
Old 03-04-2007, 06:46 PM   #6
take a pill? i dont understand, i just needed to know where the ground screw goes not a vitamin or anything like that
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
Toggle switches: With or without grounding screw? Marekus Electrical 3 11-27-2006 04:48 PM
Plastic "Old Work" wall box - Grounding Screws? strohs19 Electrical 4 01-14-2006 07:46 PM
