Old 11-21-2011, 10:30 PM   #1
Where did that wire GO?
They built the house.
Sometime after that, they built on an addition.
Then Lynn bought it.
Years went by.
Now I'm responsible.
The ceiling in the addition has a fixture. The box in the ceiling looks like it was installed at the time the addition was built. The fixture doesn't work.
I tested the bulb and the fixture, they're fine.
There are two sets of black/white wires entering the box. One black & white connects to the instrument. The other black white appear to be spliced together.
There is one box w/two switches in the addition. One controls the rear porch light, the other a wall receptacle. There are no other switches.
In the dining room wall that abuts the addition there is a blank plate. I removed the cover, there is one black, one white wire. I want nothing to do with it. Plus, it does not look (to me) like it was set up to control the fixture in the addition.
So, just where the (*&#&^(&# do the wires in the box GO? The wires are dead, as far as I can tell.
Any hints, dreams, hallucinations, fraudulent attempts at humor?
Thanks in advance.
Dana
"A child of five would understand this. Send someone to fetch a child of five."
- Groucho Marx -
TarotDream is offline   Reply With Quote
Old 11-21-2011, 10:44 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You would need a Fox & Hound set to find out.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Tags
ceiling, diagnosis, fixtures, lighting, wiring
ceiling fan wicked97 Electrical 4 08-21-2011 09:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
