Where To Connect Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 01:49 PM   #1
where to connect ground wire
hello, I am am connecting a 3wire 250v outlet to my service panel. My panel is a ge200amp service. I'm not sure where to to connect the ground wire inside the panel...i do not see a ground bus, only see 2 neutral buses. any help appreciated.
mleee999 is offline   Reply With Quote
Old 12-11-2009, 03:17 PM   #2
Remodeling Contractor
IF this is a main disconnect then the ground goes on the same bar as the neutral wire (white one)
Ground wire behind baseboard disx2000 Electrical 8 05-30-2009 12:51 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 06:25 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Grounding conduit instead of using a ground wire? stringtheories Electrical 10 08-02-2008 01:42 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
