Old 09-03-2012, 10:16 AM   #1
where is it coming from?
I have a ceiling light with two three way switches. Power comes in at the light with 12-3 going to each switch. When switch is turned"on" i have 120 v, when i turn either switch "off" i still have 90v i replaced both switches, disassemble the lighting junction box and rewired very carefully still have 90v any ideas
Mule98 is offline   Reply With Quote
Old 09-03-2012, 11:17 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
What made you start checking this? Was there a problem before?
I have a feeling you replaced something and miswired it when you put i back together.
Don't tell me, you replaced the fixture and took ALL the splices apart at the fixture?
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (09-03-2012)
Old 09-03-2012, 11:26 AM   #3
i kept replacing the bulbs(flourescents) so i decided to replace with incads. while it was apart i checked just to see what i had. please believe me that the box for all the connections is wire right. have been over it numerous times i guess the 90v was cooking the ballasts?
Old 09-03-2012, 11:48 AM   #4
Sounds like something is wired in series then.
You'll need to tell us exactly what wires you have in the ceiling and how they are connected, and also at both switches.
Mule98 (09-03-2012)
Old 09-03-2012, 11:51 AM   #5
E2 Electrician
stickboy1375's Avatar
You should use a solenoid type tester, Because you will pick up phantom voltages with a digital multimeter. Depending on what you measured...
Last edited by stickboy1375; 09-03-2012 at 11:58 AM. Reason: rephrased my statement.
Old 09-03-2012, 12:08 PM   #6
Idiot Emeritus
Yep, a digital meter will very often read voltage where there actually is none. The technical term is 'capacitive coupling'.
micromind is offline   Reply With Quote
Old 09-03-2012, 12:08 PM   #7
i have a wiggy. i'll try that thanks
Old 09-03-2012, 12:15 PM   #8
E2 Electrician
Especially in this application and how its wired.
Old 09-03-2012, 02:02 PM   #9
JOATMON
ddawg16's Avatar
Actually, it's called "Inductive Coupling".
Capactive coupling is typically found on electronic ckt boards....the higher the freq the bigger the problem.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Basement air coming up through vents and returns glsmith HVAC 6 06-02-2012 09:58 AM
Help with stink coming from Toilet area. Integraoligist General Discussion 9 11-16-2011 06:16 PM
Water coming in under bathtub thesinks Plumbing 1 07-04-2009 09:14 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 12:05 PM
screws coming loose Baffeled Building & Construction 4 08-13-2008 09:48 AM
