Old 01-23-2010, 12:49 PM   #1
Where can Pushmatic breakers be bought?
I have an older home with a Pushmatic breaker box and pushmatic berakers. One 20amp single pole went bad. Can I replace it or do I have to get the whole box redone?
peterthomas3 is offline   Reply With Quote
Old 01-23-2010, 12:57 PM   #2
you should be able to get them at your local electric supply house, or online. http://www.aplussupply.com/break/push/push.htm
journeymanj is offline   Reply With Quote
Old 01-23-2010, 01:00 PM   #3
Electrical Contractor
kbsparky's Avatar
You won't find these at your local blue or orange home centers. But most any wholesale house will either stock them, or know where to get `em.
They ain't cheap, however.
-KB
Old 01-23-2010, 01:37 PM   #4
wirenut1110's Avatar
Send a message via AIM to wirenut1110
If you can't find them locally, you can find them here
wirenut1110 is offline   Reply With Quote
Old 01-23-2010, 06:31 PM   #5
UAW SKILLED TRADES
Stubbie's Avatar
One word of caution pushmatic breakers are bolt on and you may not have a way to remove power from the breaker bus ... my point is ... you need to stay focused whether you have insulated tools or not when you remove or install breakers in a pushmatic panel. This image is a pushmatic when 'Gould' owned the brand. the captive screw at the bottom right mounts directly to the exposed panel bus. So you want to keep your fingers off the shaft of a metal screw driver....
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-23-2010, 08:03 PM   #6
retired elect/hvac/plumb
plummen's Avatar
i changed out an old panel with a truckload of pushmatics yesterday,how many doya want?
plummen is offline   Reply With Quote
Old 01-23-2010, 08:55 PM   #7
Unhappy
Stubbie (Poster #5) Speaking of being focused. I once blew a 100Amp. Main fuse, when the screwdriver slipped and made a nice, strong contact between the bus bar and the panel box. The screwdriver was embedded (welded to) in the panel box! Also, I think they were de listed by the UL!
spark plug is offline   Reply With Quote
Old 01-23-2010, 08:59 PM   #8
plummen's Avatar
i had a customer do that one time trying to save money.smoked the panel and wire up to the meter,he always calls me now!
Old 01-23-2010, 11:06 PM   #9
I did the same thing too...all of them sitting in a bucket.
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-23-2010, 11:22 PM   #10
plummen's Avatar
start your collection! ive got tons of old fp and bulldog/pushmatic and other oddball breakers ive collected over the years cuz ya never know when somebodies gonna need something late at night or on a weekend.i install mostly sq d stuff so i keep lots of it in stock,i installed a cutler hammer br series panel today that customer supplied.must say i was unimpressed and will not reccomend them to anyone!
Old 01-24-2010, 01:03 PM   #11
Unhappy
I must disagree with you on the High quality (level of protection) by the CH breaker/s! They're on par with GE and Square D? A/O FPE! We hope and pray that the quality of SD stays at the present level, because I was a big believer in FPE and I got sorely disappointed!!
Old 01-24-2010, 09:58 PM   #12
plummen's Avatar
the overall construction of the panel itself and the fact the breakers fit really lose is what im referring to,i never had a problem with the old style tan ch breakers with the hook that held them in place.
Old 11-27-2012, 06:45 PM   #13
It sounds like everyone has extra Pushmatic breakers except for me. I have a few townhouses and they all have the Pushmatic breakers. They are all to the point to where they are getting tired and in need of replacement. As of right now I could use 3 15/15's 7 15/20's & 2 20/20's any good ones out there to spare???
Dale Hackbarth is offline   Reply With Quote
Old 11-27-2012, 07:01 PM   #14
Licensed electrician
You can purchase Pushmatics from suppliers that specialize in obsolete breakers.
Old 12-03-2012, 09:55 AM   #15
I pitched all mine when I updated the panel 2 years ago. I just did not like the panel humming noises and the crappy wiring job of whomever installed it 3 decades ago.
-Andrew
DIY hobbiest
Pushmatic Panel, no main, no 2.p. breakers avery2008 Electrical 8 05-02-2009 03:51 PM
Can I install tandem breakers to stop my breakers from tripping? sofakng Electrical 1 04-29-2009 02:44 PM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 01:58 PM
Subpanels & cutler hammer arc fault breakers MoreCowbell Electrical 13 04-04-2008 11:19 PM
Need to replace Pushmatic panel? ohfreddie Electrical 1 08-27-2006 05:25 PM
