Where Can I Find "terminal Blocks"? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2008, 07:00 PM   #1
Where can I find "terminal blocks"?
I want to add a subpanel and move several of my breakers from my existing FPE main panel to the new subpanel.
This would be a simpler alternative to totally replacing the current main panel.
Rather than wire-nutting the reconnections in the main panel (some of the wires are quite large), I would like to use what I refer to as a "terminal block".
I already wire-nutted several connections when I added a generator xfer switch and it makes for a messy installation.
I think Cutler-Hammer includes a terminal blcok item in their so-called "renovation" panel - used for extending short wires to a new panel
I have been unable to find such a beast.
Anyone know where t get them?
Thanks,
Jim
j1mw3b is offline   Reply With Quote
Old 02-10-2008, 07:17 PM   #2
Are these what you are looking for?
http://www.idealindustries.com/produ...ier_strips.jsp
I was at Lowe's today and they had them.
jerryh3 is offline   Reply With Quote
Old 02-10-2008, 08:12 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
many home supply stores
most electrical supply houses
MSC
Grainger
Old 02-10-2008, 09:08 PM   #4
terminal strips!!
I been searching all over web for terminal BLOCKS, not terminal STRIPS!
Now with STRIPS, I find them. I'll look again at Lowes. Looked before there and HD and never saw them - at least not in electrical section.
Will also try local Graingers.
Thanks!
Jim
Old 02-11-2008, 12:00 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Jim are you talking about the terminal block in the upper left corner of this CH renovation panel.....
Old 02-11-2008, 09:53 AM   #6
terminal block in c-h retrofit
Yes, that's it exactly.'
Thx,
Jim
Old 02-11-2008, 11:35 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
That's what I thought. This is a very unique set-up in that it is a double stacked terminal bar insulated from the metal can of the breaker panel. The only way your going to get something like that is to order it from cutler hammer (eaton) as a replacement part. An electrical supply would possibly be able to order it for you. I've never seen this done to extend branch circuits to another panel. I do think though that an inspector possibly will accept it but I would run it by him before I attempted to do this. He likely is going to want it mounted to the enclosure much in the same manner that the neutral bar is mounted in the main panel that is existing. I'm just not real sure on this one cause I have never seen it done this way.
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Can't find fuse... Please help!!! keithstef2005 HVAC 3 01-03-2007 11:21 PM
Tips on How to find a roofer in Oregon Stormy873 Roofing/Siding 6 10-09-2006 10:39 AM
Where can i find agood carpenters? iti Carpentry 4 05-13-2006 08:23 PM
New to find a contractor - Northern NJ jhirsch1 Building & Construction 2 03-23-2005 09:24 PM
