Old 11-23-2008, 05:57 AM   #1
Where can I buy this light?
Hi all,
I have a lamp from about 6 years ago that I'd like to repair. During a move, the power cable (which is connected directly to a small white light fitting which held the globe) got damaged when the cable got pulled out of the fitting. Both the globe/fitting and cable have since been lost. The white bracket was mounted by a wire frame in a circular bracket with about a 30mm (1.18 inches) diameter.
Just wondering where the best place would be to buy/obtain a fitting + bulb + cable that might fit in the lamp? Is there a common 'standard' of light fittings?
Any help would be appreciated.
Cheers,
Gavin
Gavin is offline   Reply With Quote
Old 11-23-2008, 06:42 AM   #2
the Musigician
DangerMouse's Avatar
do you have a picture you can post?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Tags
electrical, fittings, globe, lamp, light
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 07:57 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
