Where Can I Buy This? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 04:10 AM   #1
Where can I buy this?
Where can I buy RG/11 Quad coaxial cable per foot? I have been searching around for a long time...
rgsgww is offline   Reply With Quote
Old 11-23-2008, 06:57 AM   #2
Find a cable guy doing service work and make a deal. How much do you need?
jerryh3 is offline   Reply With Quote
Old 11-23-2008, 01:30 PM   #3
It needs to be indoor...only about 100ft.
Old 11-23-2008, 01:37 PM   #4
Are you sure you need 11? If you can wait a few days, you can get 100' foot rolls of Ebay.
Old 11-23-2008, 02:09 PM   #5
Rewards Points: 506
Send a message via AIM to theatretch85
Why do you need RG11? RG11 is like what the cable company installs in the ground up to your house and then its RG6 inside the house (RG59 if you happen to be un-lucky, haha). The RG11 is pretty big coax cable, and it requires special connectors to connect to a standard coax jack.
theatretch85 is offline   Reply With Quote
Old 11-23-2008, 02:12 PM   #6
Im unlucky
I have rg/59 installed...I just decided to use rg/6Q instead. Wanted to max my install...
Old 11-23-2008, 02:18 PM   #7
Rewards Points: 506
Originally Posted by rgsgww View Post
Im unlucky
RG6 quad shield would be more than adequate in any home. That's what I ended up replacing all the RG59 that was installed in my house with. The RG6 is easy to work with and requires no special connections. I'd recommend you at least use crimp connectors for the install, but if you can afford it go for the compression connectors. Just don't use the twist on connectors, they are the cheapest and the worst connectors to use with coax cable.
Old 11-23-2008, 04:30 PM   #8
Im not sure how it will all work out...the cable co. will drop rg/11Q to my house and im going to do the hookups inside...right now I have a temporary rg/6 dropped to my house.
I always use the compression connectors...I use the Ideal brand... they are pretty easy to install...I just strip the outer jacket about 1/2" and fold back the shielding, slice the dielectric about 1/4", push the connector on, and snap it in place.
Alot of my house has rg/59...to replace it would be very difficult...I might be able to...my attic has some pretty thick areas of insulation...
Old 11-23-2008, 04:40 PM   #9
Rewards Points: 506
The connection from the cable company usually connects to a ground block on the outside of the house, what you do with it after that block is your business. Just make sure that block gets properly grounded. I have seen in some cases where the cable company will install a plastic box like a telephone demarcation box, these are usually installed higher up on the outside of the house than a ground block would be. The grounding block inside still needs to be properly grounded with this type of install as well.
Old 11-23-2008, 04:40 PM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you going to be signing up for cable tv service? If you are, sometimes they will give you what you need to prewire your house for their service. That way the installers don't have to do it later.
Journeyman Plumber
Old 11-23-2008, 04:43 PM   #11
Actually I had to install one...they forgot to install one back in 2001...
I got 10 awg to the block... goes a short distance to ground (about 4 ft.)
(its bonded to the system ground, no rods)
Conduit extends into the structure, no external boxes.
Old 11-23-2008, 04:46 PM   #12
No, I have been signed up for years. I'm having a bridge replaced that had the service conductors, cable, and phone hooked to it. Decided to go for rg/11 since I'm having all of that re ran in conduit instead of direct burial.
The original serivce was paralelled since they must have not had big enough wire...
