Where To Buy Fused Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 05:12 PM   #1
Rewards Points: 1,548
I am looking for a switch with a built in (circuit protecting) fuse that fits in a standard outlet box. The purpose is to be able to put a 20 amp. breaker back on a primarily 12 gauge circuit that has a few 14 gauge switched legs for lighting.
On this or a similar forum, someone mentioned using a fused switch on a 240 volt circuit to protect an appliance given that the circuit itself was protected at a higher current. I can't seem to find such fused switches at my local Home Depot.
Old 03-29-2009, 05:42 PM   #2
Electrical Contractor
kbsparky's Avatar
Is this what you are looking for?
Old 03-29-2009, 05:53 PM   #3
Rewards Points: 2,350
The switch that KB posted can be found at Home Depot at the fuse section. It's pretty nifty. I've used them on several occasions. But for 240 V applications, I'd use a regular fused safety switch, or fused A/C disconnect.
Old 03-29-2009, 07:46 PM   #4
kbsparky's Avatar
Originally Posted by InPhase277 View Post
...for 240 V applications, I'd use a regular fused safety switch, or fused A/C disconnect.
How about the double-pole switch + 2 fuses? Type STY
For the whole chart, click here and then look at page 2
Old 03-29-2009, 10:17 PM   #5
That would be nifty, but not readily available. I'd use them if they had them everywhere.
Old 03-30-2009, 08:11 AM   #6
joed's Avatar
Rewards Points: 13,728
I am going to guess that you are having a problem with the breaker tripping, that is why you want to change it.
Instead of installing the fused switch add the proper new circuit for your high draw equipment that is tripping the circuit.
Old 03-30-2009, 12:15 PM   #7
Thanks, just what I was thinking of.
Old 03-30-2009, 05:57 PM   #8
kbsparky's Avatar
They are readily available around here. Plus I gave you the link if you wanted to buy one online ....
Old 03-31-2009, 10:58 AM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I am looking for a switch with a built in (circuit protecting) fuse that.............
Another application would be to protect an electric motor. The latest issue of Fine Homebuilding magazine did a tool review of Portable Thickness Planers where the reviewer points out that at least one model does not have an internal circuit breaker so that:
it could burn up if overloaded
The plug fused switch that KB first posted is surprisingly low cost'
http://www.acehardwareoutlet.com/(1u55eo45luvmog2exptlgo45)/productdetails.aspx?sku=30726&source=GoogleBase
They are also stocked at my local 'BEST Hardware'
Disclaimer
& Stay Safe
.....Bob Lavery
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
