Where To Buy Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 08:32 PM   #1
Rewards Points: 260
Where to buy cable?
Do electrical supply houses sell RG6 coax flooded cable? I need to bury some cable line. I'm could just bury regular RG6 coax cable from home depot, but I'm not sure how long it will last. They don't sell direct burial cable.
bluefitness is offline   Reply With Quote
Old 11-30-2008, 09:21 PM   #2
Yeah, how much you need? You can find it online pretty easy.
Don't go for the non burial in a burial situation.
Use the right connectors in outdoor connections!
Here you go, flooded rg/6 17 cents per foot
http://www.homenetworksupply.com/pro..._id=3244669798
rgsgww is offline   Reply With Quote
Old 11-30-2008, 09:38 PM   #3
Rewards Points: 260
Thanks for the link. I'm going 120 feet. Do you think I should go with quad cable. Also, will a cable company run line for free? It runs to an outdoor patio. I'm purchasing/leasing another cable box for that area. I'm guessing no, but I thought I would ask.
Old 12-01-2008, 08:09 AM   #4
You don't need to go quad, its your choice if you do.
It depends on the cable company, I doubt mine would.
Quad is only necessary in high emi/rfi environments, outside isn't one of them.
120 ft has about 5 db signal loss, make sure your signal is strong at the house.
If you go rg/11, you would loose 3 db instead of 5, but it is much more expensive and requires special, harder to find connectors.
Old 12-01-2008, 05:03 PM   #5
Send a message via Yahoo to fburke
most cable compinies will give you the cable if you ask for it. most of the time you just have to fill out a request and it may take a day or 2 just tell them your doing a remodal and your haveing the drop run.. thay love it when the homowner has the cable prerun for them i work for a cable company so i run into this all the time.
if it;s under 250 feet use RG6 underground anything over that requst RG11 underground.
fburke is offline   Reply With Quote
Old 12-01-2008, 05:28 PM   #6
Rewards Points: 260
I wish i would have known that earlier. I ended up buying it at a local shop. It cost 35 cents a foot for monster cable RG6 direct burial. It didn't say flooded on the wire, but it did say direct burial.
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
Coaxial Cable blew tv, computer etc... ozflow Electrical 4 10-13-2008 08:06 PM
No Signal From Tv Cable LJMSURG Electrical 17 10-11-2008 09:00 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
