When You Plug Into Outlet And Light Spark Between Plug, Is This Warning Sign? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2011, 03:59 PM   #1
Rewards Points: 107
When you plug into outlet and light spark between plug, is this warning sign?
We have lived in this out about 10years ago. I think outlets are fine, but wanted to make sure.
When you plug in appliance or product into outlet and small spark appears, is this normal or is this a sign to check with electrician?
Andee77 is offline   Reply With Quote
Old 10-31-2011, 04:36 PM   #2
Retired from the grind
Rewards Points: 6,652
No, just means that there is a load on the end of the plug. My charger for my DeWalt does this, if I insert a battery into it, before plugging in.
Old 11-01-2011, 01:29 AM   #3
Sfeyelectric's Avatar
Correct, If this bothers you just make sure whatever you are plugging in is Off
Sfeyelectric is offline   Reply With Quote
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 09:20 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
mounting a light from ac outlet box trouble migelito Electrical 1 08-09-2010 06:50 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
