When To Use 14/3 Vs 14/2 - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 06:12 PM   #1
when to use 14/3 vs 14/2
Besides wiring a three way light switch, when is 14/3 wire typically used? Any examples?
mopowers is offline   Reply With Quote
Old 01-22-2010, 06:16 PM   #2
Love for Construction
<*(((><'s Avatar
15a 220v circuit
Sometimes people will use a 3 conductor wire when bringing power to an appliance before a switch.
People USED to run 14/3 or 12/3 in shops so that every other outlet was powered by a separate hot conductor and they all shared the same neutral, I'm not sure what code nowadays says about that, maybe someone else will enlighten us.
<*(((>< is offline   Reply With Quote
Old 01-22-2010, 06:26 PM   #3
Electrical Contractor
kbsparky's Avatar
Multi-wire circuits, smoke alarms (interconnection), separate switches for things like a paddle fan, or bath fan/light, or -switched receptacles, etc.
We even use 14-4 to carry both a hot and neutral along with 3-way travelers from one switch to another, to maintain the lighting circuit at the far end of the room.
-KB
Old 01-22-2010, 09:28 PM   #4
Electrician
Rewards Points: 760
KBsparky do they make 14/4 loomex or have you used armoured cable when you did this.
darren is offline   Reply With Quote
Old 01-23-2010, 02:23 AM   #5
jlhaslip's Avatar
Rewards Points: 386
Kitchen - use 14-3 to run 2 circuits to split tab receptacles.
jlhaslip is online now   Reply With Quote
Old 01-23-2010, 07:29 AM   #6
the Musigician
DangerMouse's Avatar
Originally Posted by <*(((>< View Post
15a 220v circuit
with 14-3? 15a?
i'm confused.......
DM
Old 01-23-2010, 07:41 AM   #7
kbsparky's Avatar
We get real 14/4 cable. It has a black, white, red, and blue conductors in it, as well as the bare ground.
There is also what is called 14-2-2 cable available, which has the black, white, red, and red/white striped conductors.
-KB
Old 01-23-2010, 09:52 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Originally Posted by DangerMouse View Post
with 14-3? 15a?
i'm confused.......
Me too.
Why would you need 3-wire for for a 240v circuit??
Old 01-23-2010, 09:54 AM   #9
Rewards Points: 320
yes they make 14/4 but it is usually only carried by the supply houses not the big box stores.
teamo is offline   Reply With Quote
Old 01-23-2010, 10:05 AM   #10
Rewards Points: 1,418
Originally Posted by Speedy Petey View Post
Me too.
For a combination 120/240 volt circuit, also referred to as a multiwire branch circuit when all of the loads are 120 volt (red-white or black-white).
Also for the same switched situations as may be encountered in 120 volt circuits.
For a simple 240 volt only circuit, 2 wire cable is sufficient.
Old 01-23-2010, 10:06 AM   #11
Then it is not a "240v" circuit any more.
Old 01-23-2010, 10:38 AM   #12
Rewards Points: 14
My builder ran 12-3 - 30A for hot water tank (4500 watt each element) there none simultaneous
2 hot's ( 120v ea) plus a neutral & ground. This is often done with electric ranges too
Stevies3 is offline   Reply With Quote
Old 01-23-2010, 11:10 AM   #13
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,032
Your builder done you wrong. Wire should be 10ga for a 30 amp circuit. Also 3 wire cable is not requires as a water heater does not need a neutral. 10-2 is what is called for.
Coastal South Carolina
Old 01-23-2010, 12:43 PM   #14
Absolutely correct on all points.
#12 is NOT acceptable for a 4500 watt water heater.
Probably one of those "all-in-one" builders.
"Sure, we do it all. Plumbing. Electric. Drywall. Painting. We don't need no stinkin' subs!"
Old 01-25-2010, 10:25 PM   #15
The original electricial used 12/3 in multiple places from the breaker box to where two circuits would then begin, I'm assuming to save wire. For example 12/3 was landed on circuit 17 for smoke alarms and 19 for basement lighting. Then 30' from the breaker box the circuits split and went on their separate ways. Unfortunately for me I was going to change out circuit 19 for a AFCI and add more lights but I couldn't do that without rewiring from the box so I left the existing breaker.
I also used 12/3 to add another smoke alarm to the existing and used the red wire as the common signal.
vseven is offline   Reply With Quote
14/3 used as 14/2 What to do with RED wire? C_J_GO Electrical 7 03-06-2009 07:39 PM
3way wiring problem (diagram inside) jelly Electrical 5 08-17-2008 09:15 PM
Overhead lighting Run to lights first then switches, 14/3 to both switches? twilightcall Electrical 4 07-10-2008 05:18 PM
2 switches - 14/3 cable scottmatt Electrical 25 12-11-2007 10:24 AM
Ceiling Fan 14/3 or 14/2? jelly Electrical 4 11-18-2007 07:30 AM
