When Is A Permit Not Required? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 09:14 PM   #1
Rewards Points: 91
when is a permit not required?
I have read in several places that a permit is not required to perform "maintenance on an existing electrical installation". What does that mean exactly? Sounds pretty vague...
debiasio is offline   Reply With Quote
Old 08-11-2010, 09:18 PM   #2
Electrician
Proby's Avatar
This is a big problem that I have since I service about 50 different towns.
The answer to your question is that it's up to the municipality that you are in.
If you have a specific task that you are thinking about doing, we might be able to help you with a general answer on whether it does or does not require a permit.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-11-2010, 09:25 PM   #3
Electrician
Rewards Points: 770
I take it as long as your not adding new electrical you should be fine. Things like changeing plugs, switches, fixtures, ballast probably don't need an inspection.
If you want to add a new plug or light then you techincally need a permit.
Like Proby said this can change from city to city.
darren is offline   Reply With Quote
Old 08-11-2010, 09:46 PM   #4
Rewards Points: 91
I basically want to replace an existing 2-wire 20A circuit with a grounded circuit. Other than the obvious reason of having a grounded circuit, I'd like to do this because the insulation on the old wire is so brittle; it virtually melts in your hands.
I think I know the answer to this one; I'd need a permit. But isn't this technically maintenance on an exisiting installation? Just like replacing spark plugs on your car when they stop firing...
Old 08-11-2010, 09:50 PM   #5
Electrician
Proby's Avatar
You'd definitely need a permit.
Maintenance would be things like darren specified. Changing out breakers, etc.
To run a new circuit would require a permit in most jurisdictions.
FWIW, if 1 new circuit was all that needed to be done, most people wouldn't even bother with the permit.
Old 08-11-2010, 09:59 PM   #6
Rewards Points: 91
That's what I figured. I thought about getting one, because what if something happens to the installation years down the road, after we sell the house. Can't it be determined that my work was done w/o a permit, and I'd be liable? On the other hand, many people I know do their own work and never get a permit.
What if I only do one circuit at a time, over the course of several months?
Old 08-11-2010, 10:04 PM   #7
Electrician
Proby's Avatar
Well, anything is possible. If you are worried in the least, pull the permit.
As for the future, you can be sued even if you got a permit. I've got thousands of electric installations out there that could lead to a lawsuit by someone looking for a payday. But as long as there wasn't any negligence or blatant disregard for safety, I don't think there is much to worry about. If you were to run a 20 amp circuit with phone wire it would be different, but if you are using approved wiring methods, you're good.
Now you're pushing it
BTW, I am not recommending that you do the work without a permit, I'm just saying that most people would for one circuit.
Old 08-11-2010, 11:53 PM   #8
RST
DIY Homeowner
Rewards Points: 150
There have been some discussions on here (do a search) about permit rules. As I recall Massachusetts has some quirky rules. Like I think homeowners can't do anything with the plumbing. But I think they can do electrical with a permit. Check with your town. (Or maybe someone from MA will chime in here.)
RST is offline   Reply With Quote
Basement ceiling height & Permit troubles mayo302 Building & Construction 5 06-04-2010 10:21 PM
Do I need a permit to repair my roof? shanemcguire1 Roofing/Siding 9 04-16-2009 10:12 AM
Is a Permit required for additional light ? Handy Dave Electrical 7 09-27-2008 12:21 AM
length/width deere2440 Building & Construction 17 03-01-2008 10:45 PM
No Permit for my Porch and Deck jokiddjr Building & Construction 15 06-13-2007 11:34 AM
