When Does Photo Votecs Work Just Daytime Or Full Moon Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2010, 02:31 PM   #1
When does photo votecs work just daytime or full moon light
What do you gain in amps with full direct sun compared to just light early am and late pm and don't laugh does moon light work?
Mr Roy is offline   Reply With Quote
Old 10-24-2010, 07:44 PM   #2
I've never heard of moonlight being powerful enough to generate power thru PV
Moonlight is not sunlight
It is reflected light
You need direct light - photons moving as a result of direct sunlight
Old 10-24-2010, 09:46 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Servicing Arrays
Use open circuiting, short circuiting, or opaque covering to disable an array or portions of an array for its installation or service [690.18]. Remember, PV modules are energized whenever the module is exposed to light, including moonlight.
that is from this:
http://ecmweb.com/nec/code-basics/so...6+Maintenance)
but here is the problem and why it is not practical to consider the light reflected off the moon as a source of power:
The amount of energy received from the sun is colossal: 342 watts per square meter, on average, over the course of a year. Of this, 31 percent is reflected immediately back into space by reflective surfaces in Earth's atmosphere and on the surface, but the remaining 69 percent is absorbed by the ecosystem. By comparison, the intensity of moonlight per square meter is estimated at 1 milliwatt, approximately 1/342,000th of the amount received directly from the sun.
from what I have found, if you had a PV cell that was efficient enough, you could produce usable power using solar energy reflected off the moon. It's just that there is so little light and we have not created PV cells that are efficient enough to produce a usable amount of power from that light.
btw: you can get your eyes "sunburned" from looking at the moon through a telescope.
Old 10-25-2010, 11:48 AM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
In most applications, only direct sunlight will produce usable power. The amount of light provided by direct sun is WAY more than the amount of light at dusk, dawn, or full moon. However, solar panels will produce measurable power as long as they are exposed to any light at all, even moonlight. It's just so little power that it's rarely useful. Large solar arrays can be electrically dangerous at night, though, due to moonlight.
mpoulton is offline   Reply With Quote
Ceiling fan light fixture doesn't work c4hfam Electrical 9 03-05-2011 01:01 PM
Dimmer didn't work, now old light switches don't work properly townpump Electrical 9 03-16-2008 07:28 PM
photo cell lights thst only work sometimes... kemerick Electrical 10 11-10-2007 11:29 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 05:05 PM
