When Do You Use Expansion Couplings In PVC? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-19-2012, 05:33 PM   #1
When do you use expansion couplings in PVC?
I'm trying to determine if I need to use expansion couplings in my install. This installation is in California where the climate is pretty mild with no severe temperature changes.
I'm running schedule 40 1" in a crawlspace about 40', out to an LB, buried in schedule 80 18" for about 5' then up into a workshop wall.
I've read the sections in the 2008 NEC, but I'm not sure if I need this.
Can someone enlighten me on this subject?
Thanks.
RM575 is offline   Reply With Quote
Old 08-19-2012, 05:40 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks.
I dont think you need one in your scenario. If the ground was going to freeze i would recommend one, but I think you are fine.
Old 08-19-2012, 05:43 PM   #3
Thank you. One less thing to worry about is nice.
Old 08-19-2012, 05:50 PM   #4
E2 Electrician
If you think the material is going to expand more than 1/4" you better use one though, you would be surprised how far it moves!
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Looking for feedback on deck expansion drewgold Building & Construction 4 05-26-2012 02:01 PM
Expansion joint john4153 Plumbing 0 10-05-2011 07:51 PM
no-hub terminology davefoc Plumbing 16 03-16-2009 05:15 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 05:44 AM
