-   -   When do you need a permit? (http://www.diychatroom.com/f18/when-do-you-need-permit-29305/)
tadpole59 10-03-2008 08:27 AM
I wish to do the following: change an incandescent bulb to a fluorescent light, using a plug-in for the new light.
Add an outlet on the same wall as the original one, about 8' apart. I want to change the original outlet to a GFI outlet since this is in my garage. The garage is not finished, so drilling through the studs is easy.
I would like another fluorescent light over my workbench (where the new outlet will be). Could this be run off the original light? I could run the wire in the attic to within 3' of where I want the light. By again using a plug the placement problem would be solved.
I do not have to go into the panel for any of this.
I would very much like two additional outlets, one on a different (finished) wall and one outside. I'm not sure I would be able to do those.
Anyway, for the two lights and the one outlet, do I need a permit?:huh:
RippySkippy 10-03-2008 08:52 AM
In our area it wouldn't need permitted...in others it would. Make a quick call to your local building official office tell them the scope of what you'd like to do and they will give you the scoop that matters.
jrclen 10-03-2008 08:56 AM
Every jurisdiction is different. Some use a minimum value or cost to determine when a permit is required. You can call your local plan commission or building department to check. In my area no permit would be required for this.
Yes, your new light can be connected to the existing light. If you need help, just post back.
Termite 10-03-2008 09:56 AM
Totally depends on the jursidiction's requirements, the code they've adopted, and how they choose to enforce it. Based on requirements in cities I've worked in, you would need a permit for this sort of work.
The International Residential Code (section R105.1) says that you need a permit to:
....install, enlarge, alter, repair, remove, convert, or replace any electrical...
Per 105.2, the following is exempt from permit requirements:
Repairs and maintenance. A permit shall not be required for minor repair work, including the replacement of lamps or the connection of approved portable electrical equipmet to approved permanently installed receptacles.
J. V. 10-03-2008 02:49 PM
If I called an inspector for this he would berate me for wasting his time.
Termite 10-03-2008 03:34 PM
Then he's negligent in his required duties (and if he berates you he's an a-hole too). Whether or not a permit should be issued is based on scope of work, not amount of work or the cost involved. Code clearly establishes that. He certainly has the right to choose not to permit it or look at it, but he's opening himself up to some serious dereliction of responsibility issues.
