When Bulb Blows, Dimmer Switch Blows - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2006, 07:36 AM   #1
Angry
When Bulb blows, Dimmer Switch Blows
I have fitted a 4 bar spot light in my bedroom and replaced the switch with a dimmer switch. both purchased at Argos
http://www.argos.co.uk/static/Produc...er/4313054.htm
Every thing was great with lots of light until 2 months after installing the light one of the 4 bulbs blow, and also blow the dimmer switch which made me jump out of my skin as it made a big bank.
After taking the dimmer switch off it was all black inside.
So i thought that it was just a cheap dimmer switch so purchased a different one for about £16
After replacing the dimmer switch i found the blown bulb and replaced it and all was well.
Until 3 months later the same thing happened again, bulb blow and blow the dimmer switch again, but the dimmer switch still turns on but can not change the brightness of the light, just on and off.
A week later another bulb started flickering and then went out.
Now i have Gash light in my room
Any one have any ideas?
Please Help..
mAv19 is offline   Reply With Quote
Old 05-26-2006, 03:30 PM   #2
joed's Avatar
Rewards Points: 12,866
When bulbs blow they will sometimes draw an instantaneous high current. This is caused by the filament. This high current spike can damage a dimmer.
Old 05-26-2006, 03:52 PM   #3
It appears that the bulbs for this fixture are halogen. Do not touch the bulb with your fingers when installing. The oil/salt on your fingers will make to bulb fail sooner.
Are you using the correct wattage bulb and not exceeding the rating for either the fixture or the dimmer switch?
redline is offline   Reply With Quote
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Dimmer Switch Problems? dmtm21 Electrical 2 08-07-2007 01:18 AM
Dimmer switch Remodeling Electrical 3 06-23-2006 03:08 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
Replacing Dimmer Switch dallas520 Electrical 3 05-15-2005 11:49 AM
