When Are 20AMP Receptacles Necessary? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-02-2008, 06:09 PM   #1
When are 20AMP receptacles necessary?
If I use a 20A breaker for my circuits, do I need to use 20A receptacles even if I don't plan to have 20A of draw from each receptacle? Do I need to use the 20A receptacles if I am running the wire downstream to another receptacle (GFCI outlet)?
joey b is offline   Reply With Quote
Old 11-02-2008, 06:30 PM   #2
Licensed Pro
If you are in the US, the only time you HAVE to use a 20A receptacle is when you have a single receptacle on a 20A circuit.
Old 11-02-2008, 07:08 PM   #3
Rewards Points: 150
You usually use the 20amp receptacles in garage usage where you will more than likely be using higher draw power tools. You can use 15amp receptacles on a 20amp cirucuit. Can use a 20amp circuit for lighting also. Allows you to run more off of the 1 circuit. Or as was stated when you need a dedicated 20amp circuit. Example: air conditioner, whirlpool, etc.
MikeVila is offline   Reply With Quote
Old 11-02-2008, 07:13 PM   #4
joed's Avatar
Rewards Points: 12,924
In Canada you must match the receptacle to the circuit. 20 amp circuit requires 20 amp T slot receptacles.
Old 11-02-2008, 07:15 PM   #5
Res Ipsa Loquitur
No in both cases- there is rarely a use of 20a receptacles in the normal US home. An air conditioner or large motor item might need it but otherwise, normal use in the home is not necessary. Look at all your uses and see if the plugs are T-type- likely not.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 11-02-2008, 07:31 PM   #6
Electrician
I agree, I've been doing this for a long time, and the only time I actually needed a 20 amp receptacle was for a single round receptacle, or a treadmill. But thats about it.
chris75 is offline   Reply With Quote
Old 11-02-2008, 10:34 PM   #7
Rewards Points: 150
Yeah I am installing a whirlpool and it has to be on it's own dedicated 20amp GFCI circuit. Like you said, not very common unless a special purpose.
Old 11-03-2008, 02:24 PM   #8
Rewards Points: 168
Whirlpool? Glad you mentioned that. This appliance needs special attention. Are you aware of the requirements? If not, your original post should have read " How do I connect a Whirlpool Bath".
Old 11-03-2008, 04:43 PM   #9
Rewards Points: 894
I don't understand the reference to a treadmill. Why would you need a 20A receptacle, or a 20A breaker for that matter for a treadmill?
Most of the units I have seen, and the one I have don't draw more than 5-7 Amps.
That said, I have been using the 20A receptacles everywhere, regardless of whether they are on dedicated 20A lines or not. I like the fact that they're a little "beefier" in the housing. I was told that the contacts are the same as 15A ones, but housing is stronger.
They may take more "abuse", and don't really cost that much more, since I'm only doing one here and there at a time.
Ultrarunner2017 is offline   Reply With Quote
Old 11-03-2008, 05:44 PM   #10
Electrician
Try buying an expensive treadmill... not something from sears.
They are not beefier, the manufactures use the exact housing for a 15 or 20 amp, only the face is different.
And you do know you can only use a 20 amp receptacle on a 20 amp circuit correct?
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
receptacles have no power, im at a loss reds_21 Electrical 3 10-05-2008 10:49 AM
15AMP vs 20AMP for Office? mfleming Electrical 11 04-25-2008 08:50 AM
gfci receptacles rjr Electrical 2 05-02-2007 07:16 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
