Whats Wrong Here - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-22-2009, 02:13 AM   #31
I do not see a ground conductor or a PVC conduit enclosing the ground conductor to a point not less than 4" from the bottom of the meter base. The exposed bare conductor provides an access point to the grounding conductor for the other utilities (telephone, cable, satellite, etc.) to bond into the buildings ground system. The idea is to prevent ground loops and maintain the equipotential ground plane for all equipment within the building that receives its power from the building electrical system.
Noel is offline   Reply With Quote
Old 09-22-2009, 07:29 AM   #32
All my utility grounding is inside my basement
My FIOS doesn't even have a connection outside
It goes inside & they have this huge UPS/surge where it is plugged in
Old 09-22-2009, 10:58 AM   #33
Rewards Points: 160
There is NO violation in the picture. It was a simple experiment. But I must disagree on the dryer "whats wrong pic". Without being physically able to trace out that green wire, there is no way anyone could have known it was connected to the neutral using only the picture for reference. It would only be possible if you had to connect one like that before. That green wire could have landed anywhere on the frame of the dryer. In particular the control stand on top that is always bonded to the bottom section.
If it worked before you worked on it. You did something wrong.
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
replaced 3way toggle with rocker switch - what's wrong? ellabo Electrical 8 09-22-2008 04:16 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Whats right and wrong? eric s General DIY Discussions 19 05-09-2007 08:03 PM
Does this seem wrong? LRAO Electrical 6 01-24-2007 07:55 PM
