What's Wrong Here? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 07:01 PM   #16
Licensed Pro
Congrats to HouseHelper for spotting both problems
Old 09-20-2009, 07:34 PM   #17
Great, another thing I need to go check
And I just sat down after siding all day
OK, just checked - all set
Ground strap was removed (if ever there)
4 wire connection & it's properly grounded
We bought it 6 years ago when we moved in
Can't remember if it came with the cord, if I bought it, or if I took the ground strap off or it came like that
Old 09-20-2009, 11:31 PM   #18
Rewards Points: 338
Hey kbsparky, Thanks for the reminder. If you don't do these often enough that fact (neutral bonding wire) gets overlooked. I also don't use the factory supplied strain relief, they're usually pieces of ****e.
petey_c is offline   Reply With Quote
Old 09-24-2009, 02:11 PM   #19
Just had this same thing on another forum
They moved the green/yellow stripe wire to the neutral connection
Which allowed it to be moved back for a 3 wire feed
http://www.selfhelpforums.com/showth...1220#post91220
Old 09-25-2009, 07:30 PM   #20
OK, revisit this again
Found a Mfg link
Now I'm really confusing myself
Take a look at page 4 or so where they indicate the way to connect for a 4 wire feed & 3 wire feed
http://www.estateappliances.com/data/8535914.pdf
They say for a 4 wire to connect that green/yellow wire to the neutral connection
Old 09-25-2009, 09:12 PM   #21
Semi-Pro Electro-Geek
Rewards Points: 2,852
Yes, because that's where the other end of that green/yellow wire comes from already. It's just a convenient place to "park" it, not really a necessary electrical connection. When using the three-wire setup, that green/yellow wire stays attached to the chassis, bonding it to the neutral terminal.
mpoulton is offline   Reply With Quote
Old 09-25-2009, 10:18 PM   #22
Ok, I found what was messing me up
#1 There is another diagram showing 3 wire hook-up with green/yellow also on the neutral connection. But it states that is where local codes prohibit grounding the neutral
#2 Someone on another site was indicating that green/yellow wire leads to a grounded connection & does not tie into the neutral
My dryer had a grounding strap, so no way for me to verify that
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Are my windows installed wrong? bogamilsan Carpentry 15 05-01-2009 04:40 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 09:09 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
Drywall,what am I doing wrong? Feangel Painting 4 06-19-2007 09:17 PM
