What's Wrong Here? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 03:41 PM   #1
Electrical Contractor
kbsparky's Avatar
What's wrong here?
A little quiz for our members here. What can you find wrong in this picture? This is the terminal block on a standard electric clothes dryer:
-KB
Old 09-19-2009, 03:54 PM   #2
the Musigician
DangerMouse's Avatar
looks to me someone forgot something ELSE besides the cover... lol
DM
Old 09-19-2009, 04:08 PM   #3
kbsparky's Avatar
OK, let's not worry about the cover. I removed it to fix the problem(s). Took the photo before making repairs.
I'll have the repaired photo up later in this thread, and the final one with the cover installed, if you want.
-KB
Old 09-19-2009, 04:27 PM   #4
Rewards Points: 2,350
The first thing I notice is there is no strain relief on the cord. Is the neutral-frame bond disconnected?
Old 09-19-2009, 04:58 PM   #5
the Musigician
that's all i can see besides no cover....
DM
Old 09-19-2009, 05:56 PM   #6
" Euro " electrician
frenchelectrican's Avatar
no strain relef cord clamp there that part I know for sure.
Not sure but feel safe that the netural bond is allready removed.
Merci,Marc
Old 09-19-2009, 06:14 PM   #7
Licensed Pro
Ground/neutral connection (for three wire cord) has not been removed; no strain relief on cord.
Old 09-19-2009, 06:19 PM   #8
Its turned around backwards...that's the back.
mics_54 is offline   Reply With Quote
Old 09-19-2009, 07:13 PM   #9
kbsparky's Avatar
Here is a closer view:
-KB
Old 09-19-2009, 07:26 PM   #10
Should the ground with the yellow stripe be on the neutral terminal?
seems right to me for 4 wire connection...a 3 wire cord would have a ground strap from the neutral.
Old 09-20-2009, 06:42 AM   #11
Code05's Avatar
Rewards Points: 1,104
The fact that you said repairs and that ground connection looks discolored/burnt makes me curious. The red termination looks slightly discolored also, or maybe I just need new glasses.
BTW, where in Delmarva are you? I used to live in Salisbury, MD.
Code05 is offline   Reply With Quote
Old 09-20-2009, 10:47 AM   #12
Rewards Points: 204
Theres nothing wrong with it. It's the question thats wrong.
If it worked before you worked on it. You did something wrong.
Old 09-20-2009, 11:35 AM   #13
I can't see anything!
Willis
williswires is offline   Reply With Quote
Old 09-20-2009, 05:47 PM   #14
kbsparky's Avatar
OK, here is the same dryer, after "repairs" have been made:
-KB
Old 09-20-2009, 05:53 PM   #15
kbsparky's Avatar
Congrats to HouseHelper for spotting both problems:
1) No connector or strain relief on cord where it enters the appliance
2) Neutral bonding wire still connected.
Herein lies what I consider to be a major problem: The neutral bonding wire is left in place when many folks install the 4-wire cord, making a return parallel path over the ECG. That green wire with the yellow strip originates from the neutral terminal, even though it is not readily apparent on visual inspection.
It MUST be removed from the green screw, and either insulated, cut out, or placed on the neutral terminal for a compliant installation of a 4-wire cord.
All too often, these cords are installed by untrained warehouse personnel, truck delivery drivers, or even appliance salespersons. This results in a non-complaint installation such as was in this case.
-KB
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Are my windows installed wrong? bogamilsan Carpentry 15 05-01-2009 03:40 PM
Faucet handle faces the wrong direction. diyntn Plumbing 1 04-22-2009 08:09 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
Drywall,what am I doing wrong? Feangel Painting 4 06-19-2007 08:17 PM
