What's Needed For This? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 11:29 PM   #16
Ok this afternoon I finally got one located and ordered. I tried even to get the toggle type but as soon as you use them for 240 volt they get knocked down to 10 amp. But anyway I have a dpdt 20 amp that on the description said 120/270 volt yes 270.
Can I get some kind of schematic as to how to connect up the switch from the panels 20 amp breaker through the switch and then to the two 240 volt elements ? Actually I already know how to connect to the vats but more into the switch and branch out to the two vats. I would imagine its not as simple as connecting the two 240 volt line ins from the panel to the centre poles then two wires from each vat to the remaining 4 screws?
Disisme is offline   Reply With Quote
Old 04-19-2013, 01:49 PM   #17
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Disisme View Post
Ok I ask again can this be found for a square d panel because I'm having a terrible time finding even a dpdt 20 amp 240 switch?
Which square D ???
Homeline or QO ??
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-19-2013, 05:13 PM   #18
Originally Posted by Philly Master View Post
Which square D ???
Homeline or QO ??
I wish I knew , I looked all in the panel with door cover removed , exterior of fuse box around edges and I checked inside and exterior of door and there are no labels or markings. Only reason I know its square D is because door open button has Square D symbol as well as the box is full of square D breakers.All I can say is one of the breakers has a sticker that says interchangeable with square d QO panel. Can you help me out for what to look for to determine whether its a Homeline or QO.
I really appreciate all the patience and help
Lynn
Old 04-19-2013, 05:19 PM   #19
Rewards Points: 516
Lynn
QO >>>>>
HOMELINE >>>>
Old 04-19-2013, 06:37 PM   #20
I'm out at the show with the misses but defiantely the first one qo.
Old 04-19-2013, 08:05 PM   #21
dmxtothemax's Avatar
Rewards Points: 5,362
We need a picture or diagram of the switch and it's connecttions ?
Do the terminals have any numbers or letters to indicate what's what ?
Usually they are labelled in some way.
dmxtothemax is offline   Reply With Quote
Old 04-19-2013, 09:16 PM   #22
Sorry I didn't realize each one had different configuration.
Ok I will have to wait until it comes in, the guy said it should be in by next Friday so hopefully you helpful guys will stay tuned.
Slab leak advice needed! Help MsTFT Plumbing 23 01-31-2013 03:34 PM
Replacing rooftop deck - permit needed? esk8mw Building & Construction 5 01-27-2012 02:02 AM
Fan size needed for Spray Booth (CFM) Sandy 1150 Painting 0 12-21-2011 07:22 PM
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 01:53 PM
Face nail needed with Bona r851? bakerzdosen Flooring 0 08-01-2011 07:56 AM
