Whats Involved In Converting My Generator To Electric Start? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2012, 01:26 AM   #1
Rewards Points: 91
Whats involved in converting my generator to electric start?
I have a DeVilbiss generator with a 10hp Tecumseh motor (model HM100). I found starters on Ebay but I was told that I need to have other stuff like a ring gear which is very expensive. So whats the scoop on this poop?
sofasurfer is offline   Reply With Quote
Old 08-04-2012, 07:23 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Unless the generator is already set up to accept a starter (things like the ring gear and wiring provisions) IMO is not AT ALL worth considering it.
Old 08-04-2012, 09:48 AM   #3
Rewards Points: 760
I did this a few years ago when you could still get Tecumseh parts cheap.
You will need a starter, a ring gear, and a starter solenoid at a minimum. Hopefully your shroud already has the bump out, mine did.
I also put in a charging coil to keep the battery charged when running. You really don't need that. I keep it on a trickle charger so it's always ready.
For the starter, get it new. It's not worth dealing with a used one. They do come in 12 and 120 volt versions so make sure you get the 12 volt.
For the ring gear (just the the flywheel assembly), maybe you can find one online or sometimes your local lawnmower shop will cut you a deal. They are very common on snowblowers but if you wanted that charging coil it may not have the correct magnets.
Basic wiring and you're up and running. It's not a difficult or time consuming conversion, just the cost of the parts nowadays.
AandPDan is offline   Reply With Quote
Old 08-04-2012, 10:46 AM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I find it easier just to send the wife out and start it....
Old 08-04-2012, 11:48 AM   #5
Rewards Points: 760
Actually, my dad used to do that
My parent's have had this thing for about 15 years. It's just that now it's getting a bit difficult for them to pull the rope, especially when it's very cold out. Since the thing runs like a top, and we've converted it to propane, it was worth it.
Old 08-04-2012, 04:53 PM   #6
Rewards Points: 91
I found a flywheel on line that is listed as for an 8hp (mine is 10hp) but the part # is correct...611091. Can I assume this is correct or is there supposed to be a # stamped on the flywheel that the guy can look at for me?
Old 08-04-2012, 05:03 PM   #7
Rewards Points: 760
That is one of the part numbers. They vary depending upon the charging system. I don't recall if it stamped on the flywheel or not.
Make sure, before you buy things, that the block has the 4 tapped holes for a starter to mount too.
Old 08-04-2012, 05:04 PM   #8
Rewards Points: 91
Yes I have the tapped hole and the cover is bumped out, but alas, no ring gear.
Old 10-31-2012, 09:34 PM   #9
how to convert a 10hp tecumseh to 12v electric start?
OK , so here is what im asking; is that allI need is a tooth fly wheel and a 12 volt start and a set of jumper cables and that it? no need to about the magnets ? i seem a flywheel on ebay. my motor is on a genertor and i was going to jump off the car battery using a trigger start button between the red on the jumper cable and the bolt on stater. not look to put out a lot of money, the flywheel is 50 and the new start is46.
FRITTER72 is offline   Reply With Quote
Old 10-31-2012, 10:24 PM   #10
Rewards Points: 760
All you need is the flywheel with ring gear (toothed) and a starter. There will be some magnets on the flywheel, for the ignition system. You don't need additonal magnets, they are for the charging system.
Old 11-01-2012, 01:48 AM   #11
Wink
thanks AandPDan
Old 11-01-2012, 05:35 AM   #12
Rewards Points: 91
Original poster here.
Haven't converted mine yet. Flywheels are $139.00. Still looking for cheaper.
Magnet question... I see flywheels advertised as "no magnet". Don't all flywheels have magnets. I see in the above post that there are 2 types of magnet? Ignition and charging?
Let me get this straight...Ignition magnet energizes the coil and spark plug? Doesn't that also charge a battery, or is this why I need extra magnets...for the charging?
So, I can buy ANY flywheel (correct part number 611091) and it WILL run the motor? But if I want to charge a battery I need a special flywheel with an extra set of magnets? Is this a different flywheel or the same one with a special magnet installed?
This is insane!!!
I want a charging flywheel but I am afraid to spend the money and get a wrong one. AHHH!!
Old 11-01-2012, 09:21 AM   #13
Rewards Points: 760
All the flywheels have the magnet for the ignition. Not all have the magnets for the charging system. The one for the ignition is on the outside of the flywheel.
You likely don't need a charging system.
There are MANY configurations of charging systems available. Some have more magnets than others. The stators also change and some systems have voltage regulators. It all depends upon what you need/want. Basically the magnets for the charging system are under the flywheel as is the stator. They are part of the flywheel assembly.
electric starter Barry J Landscaping & Lawn Care 7 01-22-2011 04:13 PM
Electric Heater: Fan Does Not Start on Auto Setting Phreek HVAC 8 12-10-2010 07:47 PM
Converting Gas Range with pilot lights to electric start gas range waterhead Electrical 5 01-02-2010 07:16 PM
How To Rebuild Tecumseh Electric Start? asian432003 Landscaping & Lawn Care 3 09-13-2009 05:34 PM
adding electric start to Makita generator Mr Chips Tools 6 02-16-2009 07:55 PM
