What's Hot? What's Not? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2010, 09:50 PM   #1
CNMDESIGN.COM
What's hot? What's not?
Picture this.
Wire #1 has a black/white and ground.
Wire #2 has a black/white and ground.
Wire # 3 has a black/white and ground.
Wire #1 is coming from GFI outlet.
Wire #2 is coming from vent fan in bathroom ceiling.
Wire #3 is coming from light over shower.
Need to hook all them to a timer switch that has one white wire, one black wire and one red wire. The switch is the GE single pole,auto shut-off timer indoor in wall 15069. It will handle both fan and light.
CNM Design is offline   Reply With Quote
Old 02-16-2010, 09:53 PM   #2
joed's Avatar
Rewards Points: 13,332
hook all whites together including timer.
wire #1 black to timer black
Wire #2 & 3 blacks to timer red.
Old 02-17-2010, 10:25 AM   #3
CNMDESIGN.COM
Old 03-04-2010, 02:51 PM   #4
CNMDESIGN.COM
Using a solid state timer in stead of a the mechanical above. I heard they last longer.
Picture this.
Need to hook all them to a timer switch that has one white wire, one black wire one blue wire and one green wire. The switch is the GE single pole, auto shut-off timer indoor in wall 15088. It will handle both fan and light.
The directions state:
Connect wires per wiring diagram as follows:
Black lead to circuit’s (Hot) line conductor.
Blue lead to circuit’s load conductor
White lead to circuits neutral conductor
Green conductor to ground
Old 03-04-2010, 05:08 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
Just follow joed's wiring, using the blue wire for the red wire.
Old 03-04-2010, 05:11 PM   #6
Rewards Points: 1,538
Hook all whites including the time white together.
Hook the bare wires and the time green together.
Hook cable 1 (from panel) black wire to timer black.
Hok cable 2 and 3 blacks (light and fan) to timer blue.
AllanJ is online now   Reply With Quote
Old 03-04-2010, 05:13 PM   #7
CNMDESIGN.COM
Thank's
