What's Happening Here? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 02:05 PM   #1
What's happening here?
I have a switch to two overhead lights in our bathroom. The switch is likely faulty. Didn't run before, now it works. If I run a neon tester to the switch, it shows power as long as the switch is in the OFF position. However, when I put the switch in the ON position, the neon tester goes out. Why would that happen?
tedboxer is offline   Reply With Quote
Old 07-06-2010, 02:40 PM   #2
When you say in the off position do you mean it is positioned down, or it has a marking somewhere on it that says 'off'. If the lights come on when it is in the down position and on when it is in the upright position, then it was likely just installed upside down.
However if it wasn't working and then one day just starts working I'd pull it out and replace it right away as something about it just ain't right.
Troglodyte is offline   Reply With Quote
Old 07-06-2010, 03:02 PM   #3
" Euro " electrician
frenchelectrican's Avatar
I got the " picture " what you try to do here if I am right you did use the neon test light on both switch screws that why when the switch is off the neon light lit up when the switch is on the neon light go off that is correct if the switch is functing correct.
I know you mention not run before so the best bet is replace the switch they are not that expensive useally under 1 euros for it.
but make sure you disconnect the power source to this switch before you do anything and make a note how it hook up few case you may have backstabbed devices move them to the screws or just get new switch and just go with screw do not bother with backstabbing unless you have backwire that is diffrent { that a much better verison due you can able screw the plate to tighten up good }
when you have the switch out it will be good time to check any other connections to make sure they are tight that included the netural { white } conductor as well.
Merci.
Marc
not sure what is happening here cprao Plumbing 14 07-05-2010 11:24 AM
This is whats happening on my sagging floor. speedster1 Building & Construction 15 03-09-2010 04:36 PM
Just Wondering if this is happening to all here!!! localtradesman Off Topic 10 11-02-2007 01:41 PM
What's Happening Here? W3ATB Introductions 8 11-15-2006 09:30 PM
