What's The Deal With Derating - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2008, 11:59 PM   #1
Rewards Points: 150
What's the deal with derating
What's the Max number of 12/2 NM cables I could run through a 3/4 hole? And If I am fire caulking how many of the same could be run, also through a 3/4 hole? If I am reading right, no more than two NM cables through a single hole that is fire caulked. Is this right.
Also I have an 1-1/4" hole in the joist above the main panel, How many 12/2 NM's can I run through this hole to the panel before it is considered bundling? ( No fire caulking invloved) Thanks
James Con is offline   Reply With Quote
Old 06-18-2008, 02:48 AM   #2
Rewards Points: 150
Can anyone help me out here. Thanks
Old 06-18-2008, 06:40 AM   #3
Electrician
This question will be answered will many opinions, here is mine. Bundling does not exist when running wires through bored holes in wood, it just does not meet the definition of bundled, ( The Nec does not define bundled).
As far as the fire caulk, Its when two or more current carrying conductors
pass through wood framing. But, you can use the 90 degree chart to derate, so basically you can run 9 current carrying conductors before the wires actually take a hit.
chris75 is offline   Reply With Quote
Old 06-18-2008, 12:28 PM   #4
Rewards Points: 150
Thanks for responding Chris. So I could send a total of nine current carrying conductors through this hole. Now is that 9 conductors meaning 4 -12/2 cables.
Old 06-18-2008, 04:43 PM   #5
Electrician
If that hole is not getting fire caulked, put as many as you want through it.
Old 06-19-2008, 12:20 AM   #6
Rewards Points: 150
Gotcha, Thanks Chris
Old 06-20-2008, 10:15 AM   #7
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
As Chris said, the keyword is fire caulked or even sealed with insulation.
wirenut1110 is offline   Reply With Quote
$10 per sq. ft..... good deal? KUIPORNG Landscaping & Lawn Care 3 04-21-2008 03:59 PM
skid plates -- big deal? blakekr Appliances 1 03-02-2008 11:35 AM
Hot Lithium Ion Drill/Driver Deal End Grain Tools 6 12-16-2007 11:26 AM
Best way to deal with my neighbours mouse problem? KUIPORNG Pest Control 6 11-13-2007 09:26 PM
What do YOU think of this HARDI siding deal?? justdon Remodeling 3 09-16-2007 12:54 PM
