What's The Best Practice? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2011, 06:03 PM   #1
Rewards Points: 119
What's the best practice?
Hi all,
I am new in Canada, that's why my question below.
I want to put a piece of furniture in my basement, but I have to remove a lamp which is on the wall.
Once I disconnect the lamp and take it off, I will need to put three caps on the wires to insulate them.
Is it good practice to put them inside the drywall (if the original holes are big enough to let the caps through) or is it better to leave them out the wall and just put my piece of furniture in front of them?
Thank you
Alex
Metallo is offline   Reply With Quote
Old 01-12-2011, 06:05 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Well, there should be an electrical box that the wires are in. Hopefully the wires are not just sticking out of the wall.
Just cap them off, fold them neatly back in the box and install a blank plate on the box. DO NOT cover it/them up with sheetrock or some other patch. They MUST remain accessible.
Old 01-12-2011, 06:14 PM   #3
Rewards Points: 119
Hi,
thanks for the quick reply.
But the lamps is hooked to the wall, you mean that when I remove it I will find the box?
That would be ideal, let's see, the house I just bought seems to have a good electrical system according to code, so... end of the week I will confirm it!
Regards
Alex
The Following User Says Thank You to Metallo For This Useful Post:
Speedy Petey (01-12-2011)
Old 01-12-2011, 06:16 PM   #4
Sfeyelectric's Avatar
Originally Posted by Metallo View Post
Hi,
Regards
Alex
Yes the lamp is more than likely screwed into this box.
Sfeyelectric is offline   Reply With Quote
The Following User Says Thank You to Sfeyelectric For This Useful Post:
New to DIY website, but not to DIY in practice! Alida Introductions 3 03-20-2010 07:25 AM
Tiling in two planes common practice? rocketdoctor Building & Construction 1 12-16-2009 08:14 PM
Granite counter best practice or sham? kdh1234 Remodeling 2 08-07-2009 06:18 AM
Is it bad practice to drywall like this? J187 Drywall & Plaster 15 05-09-2009 01:16 PM
I need practice and experience Yoyizit Landscaping & Lawn Care 2 08-08-2008 08:35 AM
