What Would Be Involved In Moving My Electrical Panel About 4" Forward? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 11:13 AM   #16
concretemasonry's Avatar
Rewards Points: 2,566
Insulating behind the box would really be meaningless since it is a small area and the insulation is really not needed. Anything you put behind the plywood (if moved out) would not be insulated and would be a thermal bridge anyway.
Just frame the wall out properly and put on a good tight fitting door with some appropriate insulation of the inside. At the least you really do not have to deal with infiltration in a basement. You will never see any heat loss on your utility bills and with a washer fully of hot water and dryer adjacent to it. I would be more concerned about the window thermal properties and the tin dryer ducts that can also get cold if you have a real winter.
Just don't try to nit-pick details and create theoretical imaginary problems in your mind and make everything more complicated and prevent concentration on the bigger things.
Dick
concretemasonry is offline   Reply With Quote
Old 05-22-2013, 12:25 PM   #17
Rewards Points: 1,192
In America, we can't hide a sevice panel in a cupboard or closet.
bobelectric is offline   Reply With Quote
Old 05-22-2013, 01:17 PM   #18
joed's Avatar
Rewards Points: 11,534
Originally Posted by Kyle_in_rure View Post
Off topic, but what brand of panel is that? I've never seen one like that.
It's an FPE stablok Canadian version with the service conductors in a separate compartment as required in Canada.
Old 05-22-2013, 03:20 PM   #19
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Dick
Not only insulating behind there, but the entire wall. Moving the panel is just a step in order to insulate behind it. Like Mike Holmes would say "Do it right". The window will probably be changed at some later point to something more energy efficient, but it is double pane so much better R value than empty cinder block. Ducts are an issue but much smaller surface area to get cold. The point of the insulation I'll be adding is also to act as an air seal (will get it spray foamed). Cinder block is porous. Insulation only works if you account for every single heat loss, and air leaks are the biggest ones. Ducts is really about the only thing I can't do much about but I could always put a bit of insulation over a couple feet of it. Though the little flapper at the end is where the big heat loss is.
I can always move the washer and dryer if it's a huge issue. Was this way when I bought the house.
The panel is a FPE Stab Lok, eventually I want to change it, but think that particular model is not an issue anyway, it's the older ones. I see them everywhere even in hospitals. Though more commercial versions.
Worse case scenario I'll just do the door idea, if I make it seal properly I might be ok. But if I can get this done for a couple hundred bucks or what not I may as well go for it. If it ends up I need the whole thing changed then I'll never mind.
Old 05-22-2013, 04:09 PM   #20
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,360
Joed.... That's a Federal Pacific Stablock.... have you had problems with canadian version as we have with the US FP panels.
Not that you want the cost, but considering you might want to replace it, now would be the time.
If you are not aware of FP Stablock issues, google Federal pacific.
My daughter just bought an old 1953 with a terrible FP. We'll be changing it out as soon as possibel
Best
Peter
MTN REMODEL LLC is online now   Reply With Quote
Old 05-22-2013, 04:26 PM   #21
Wire Chewer
Rewards Points: 46
Pretty sure the Canadian Stab Loks are ok. There's Federal Pacific (US) then there's Federal Pioneer (Canadian) which did not have issues. I do want to change it at some point though as I have no more room.
I just called hydro and they do require an inspection, so on that note to simplify things I'll just get an electrician to do it so I'm not waiting days for an inspector and no power. Depending on extra cost I may even get the electrician to just change that whole cut off to 200 amp so I can change the panel in the future as I have no more room. Though I did free up a double pole breaker, so I'll probably use that to feed a sub panel to my server room, and I can move a few things on that.
The Following User Says Thank You to Red Squirrel For This Useful Post:
MTN REMODEL LLC (05-22-2013)
Old 05-22-2013, 04:33 PM   #22
If you're having the sparky change out the service feed, you may have a pleasent surprize that changing your whole panel may not be that bad.
Old 05-22-2013, 04:42 PM   #23
Wire Chewer
Rewards Points: 46
Yeah I'll probably get a quote for that too. Might be worthwhile to just get it done once and for all.
Old 05-22-2013, 04:52 PM   #24
The concrete block wall that is in place has a higher "R" value than most double pane panels. Plus, the window is exposed to much lower temperature on the exterior than the block wall, that has the benefit of thermal inertia of the block and soil that is warmer than the outside conditions in the winter.
Dick
Old 05-22-2013, 06:58 PM   #25
joed's Avatar
That panel is still available for sale in Canada. It is a commonly used panel. We did not have the issues found with the US panels. I believe it was two different companies.
That panel appears to be an upgrade already based on the separate disconnect switch. That house probably had a fuse panel with no main disconnect in it and has been updated to the FPE panel you see.
The Following User Says Thank You to joed For This Useful Post:
Old 05-22-2013, 08:10 PM   #26
Rewards Points: 528
Speaking on panel locations/relocating an water sources ,this one surely must be moved.wonder what they were thinking when installing..
What would be involved in moving my electrical panel about 4" forward?-imag0499.jpg
hidden1 is offline   Reply With Quote
Old 05-22-2013, 08:59 PM   #27
Joed.... I'm not likely to be up that far North.... but that is interesting. I'm thinking it must be two different companies as you say. Federal Pacific w/stablock was sold with alot of different names taken off Federal Pacific ... like FPE and Federaral Pack... when I see FP letters involved, I pull the meter and start rewiring.
But as someone earlier said and identified.... I never heard of Federal Pioneer. Plus, if it's as dangerous as it is down here, you'd know about it. Everybody is aware down here.
Company went out of business many years ago...under suits and delisting,,, but of course there are still many panels around. Aftermarket breakers are available... but exhorbitant $40 for a 15 or 20 A single... 70-90 for a 30A+. We don't have them in Co, but they sure were popular in Cali. Both my kids places had them, one still does, and they were wobbly loose... just plain ugly and scarry.
Best
Old 05-22-2013, 09:08 PM   #28
Probably either drinking beer or getting older.... sure looks convenient if you have to work on it.
Old 05-23-2013, 12:06 AM   #29
Wire Chewer
Rewards Points: 46
Don't aim too high! LOL
Reminds me of a server room I saw that was in the staff bathroom. There was a couple Cisco switches and other equipment on a shelf just over the toilet.
MTN REMODEL LLC (05-23-2013)
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
Bonding Electrical Panel folkda Electrical 3 11-03-2012 12:37 AM
Electrical Panel question pattyobrien3 Electrical 19 09-14-2012 12:11 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
