What Would Happen If... Improper Generator Installation ? - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-02-2009, 09:35 PM   #1
What would happen if... Improper Generator installation ?
I sold a Honda generator to a gentleman who was going to use it @ home in case of emergency, like a power outage.
He asked me an interesting question that I didnt know the answer to.
He said that in the case of a power outage he was going to run a cord from the 220 recept on the generator to a 220 recept in his garage and backfeed the panel. I told him it would work but I didnt think it would be safe in the case where power was restored while the generator was running??
I'm not sure what would happen, fireworks?
Steven Jackson is offline
Old 12-02-2009, 09:38 PM   #2
NOT SAFE & ILLEGAL as far as I know
He would be backfeeding not only the house but the electric lines
And the transformer works both ways, stepping that small voltage up to higher voltage & possibly killing someone working on the wires
Scuba_Dave is offline
Old 12-02-2009, 09:41 PM   #3
I forgot to mention that I told him if he had a main breaker in his panel to turn it off.
He wasnt sure.
Pretty much a bad idea and dangerous as you mentioned, in the case of re energizing the lines via the XFMR on the pole.
Old 12-02-2009, 09:48 PM   #4
I've always been told it's illegal and unsafe-- even if you turn off the main breaker so that you don't feed the lines. I hope someone has something more official.
finnimus is offline
Old 12-02-2009, 09:51 PM   #5
Lightbulb
Still NG. Like Scuba Dave said. ILLEGAL and DANGEROUS! First thing you will need a TRANSFER SWITCH (Either Manual or Automatic). (ATS) to make certain that the power coming out of the emergency generator is NEVER fed back to the Utility lines!!!
spark plug is offline
Old 12-02-2009, 09:57 PM   #6
300zx's Avatar
Post
I had a service call where a guy told me he hooked up his generator and forgot to turn his main off (This was about 8 years ago) power went out and he started the generator and then the power came back on It killed his generator and every Tv in his house (4 of them 1 bigscreen) And everthing that was low voltage (security system,cordless phones,And so on)Cost him alot to fix!! do it the right way, with a transfer switch. ...
300zx is offline
Old 12-02-2009, 10:02 PM   #7
Wow, thats alot of damage.
Old 12-02-2009, 10:41 PM   #8
In this state there is a $15,000 fine for doing just that plus you are held liable if a lineman gets hurt. You must have a transfer switch you can not just turn off the main breaker.
hayewe farm is offline
Old 12-03-2009, 05:03 AM   #9
the Musigician
DangerMouse's Avatar
$15,000 fine here too. get a transfer switch or run extension cords off the generator to just what you want to run.
DM
DangerMouse is offline
Old 12-03-2009, 06:58 AM   #10
If I was not sure of the answer to a question like that, I would say to call the manufacturer and ask. I would explain that manufacturers design these things and know all about how they work and how they can be safely connected as well as dangerous situations to avoid.
In other words... Get it straight from the horse!
Honda Power Equipment Customer Relations
770-497-6400
Honda generator - Connecting to a home information...
http://www.hondapowerequipment.com/p..._connecttohome
Billy_Bob is offline
Old 12-03-2009, 09:02 AM   #11
joed's Avatar
Rewards Points: 13,766
Also the cord he would need to use would have two male ends. It's called a suicide cord for a reason.
joed is online now
Old 12-03-2009, 10:06 AM   #12
Rewards Points: 252
www.interlockkit.com
J. V. is offline
Old 12-03-2009, 11:46 AM   #13
Rewards Points: 1,910
JV's got a solution there. Note that all it does is mechanically force you to shut off the main breaker in order for the breaker from the generator feed to go on.
please do not suggest a dangerous way of connecting a generator as "safe"
Moderator
jogr is offline
Old 12-03-2009, 11:53 AM   #14
The plan is NOT safe as it is not an approved method & can at worst kill someone
Old 12-03-2009, 12:02 PM   #15
Its not approved FOR A REASON
Closed Thread
Condensation pump - disaster waiting to happen bchristal HVAC 4 08-01-2009 07:00 PM
Does anyone know what happen to my plants?? just_another_guy Landscaping & Lawn Care 5 06-30-2009 07:15 PM
Improper ventilation?? mechanical_prints2 Roofing/Siding 6 10-30-2007 09:42 AM
Run submerged waterfall pump without water, what will happen herbolaryo Electrical 2 08-15-2007 06:03 PM
What will Happen if I pmb003 HVAC 2 09-21-2005 06:55 AM
