What Wire To Use When Adding Wall Sconces? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 11:01 AM   #1
Rewards Points: 308
What wire to use when adding wall sconces?
I'm adding a pair of indoor wall sconces in my living room. I'll be piggybacking from an existing switch for the line. Should I just use 14-2 wire or would it be necessary to use 12-2? I look forward to your responses. Thanks!
smokey847 is offline   Reply With Quote
Old 03-19-2012, 11:05 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 850
Lighting....14-2
FYI...I like wall sconces....we like how they provide indirect lighting....very effective...
I'm using small CFL's in all of mine....means I can leave them on as accent lighting......translation...they are using like 6w/fixture (2 bulbs each fix). Hence, I'm not putting any real load on the wiring...
Old 03-19-2012, 11:05 AM   #3
Pure Genius
Rewards Points: 150
Use whatever wire is currently used to feed the existing circuit.
Dierte is offline   Reply With Quote
Old 03-19-2012, 11:29 AM   #4
Licensed electrician
Rewards Points: 1,054
That would depend on the size of the breaker or fuse on the circuit. A 20 amp circuit requires #12, a 15 amp circuit could use #14 or #12. The #12 will be harder to work with and take up more space in the box.
Correct gauge wire on wall heater?? Master Brian Electrical 4 11-16-2010 02:48 PM
adding rock panels to old stone wall adzling Building & Construction 0 09-27-2010 12:41 PM
Adding support to a wall, need to reroute waste pipe and more sdrzewic Building & Construction 2 08-23-2010 01:16 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
