If you plug in something that uses more then 15 amps it will trip the breaker. It should be changed to standard 15 amp receptacle because it shouldn't be on a 15 amp circuit. Do you know if the wiring is 14 ga or 12 ga?
Why wouldn't a 20A receptacle be allowed on a 15A breaker? My understand is that the point would be that the weakest point in the system should be the breaker, and that is the case here.
I may be wrong, but I'm thinking that it's wrong because someone could see the 20a receptacle, and change the breaker to 20a with the wiring being 14 guage.
all it will do is trip the breaker, but just remember, breakers have failed before so why take the chance.. if the breaker trips over and over again it could get weak and fail to trip when you need it to, overheating the wire and causing a fire
The worse thing that will happen is someone will plug a 20 amp device into it and it will trip the breaker.
A 20 amp breaker with 14awg wiring is more serious though. Adding a 20 amp load will put stress on the wires that it was not designed for, and the breaker wont trip to protect the wiring.
If you have the old faulty FPE breakers, then it really does not matter what size the breakers are, it's still going to catch on fire. :laughing:
As far as the, at this point hypothetical, possibility of plugging a 20 amp load into a 15 amp circuit with a 20 amp receptacle... How many 20 amp loads are there really that would not be able to plug into a 15 amp receptacle? I can't claim to know everything that might get plugged into anything, but frankly I can't think of anything I've seen that uses the 120V 20 amp plug shape.
Folks install 50 amp receptacles on 40 amp circuits all the time. What is the difference here? How many places have burned down from this? I'd be willing to bet that you can't think of =ANY=
Answering the question, probably nothing will happen...but the NEC doesn't allow 20 amp receptacles on a 15 amp circuit. That being said, my treadmill was listed as requiring a dedicated 20 amp circuit, but it works fine on the existing 15 amp circuit. As mentioned earlier in this thread, don't use other devices when using the treadmill. And I recommend a surge protector for the electronics in the machine.
A single receptacle installed on an individual branch circuit shall have an ampere rating not less than that of the branch circuit.
20 Amp is not less than 15, the same as 50 Amp is not less than 40. :whistling2:
Now if you wanted to install more than one receptacle (I noticed you stated receptacleS), then section 210.21(B)(3) would apply in which case you are correct.
A duplex outlet would trigger the provisions of 210.21(B)(3) in any instance.
I think that what could happen that would be bad is when the breaker keeps tripping due to a >15a load, and someone replaces the breaker with a 20amp, not realizing that the wire is 14 AWG.
I do have to say that I haven't seen a residential 20A appliance (with a plug) either. The last 20A 120V device I touched was a UPS. It was expandable, so it had the 20A cord to accommodate its maximum possible load.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
