What Went Wrong?? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 12:30 PM   #1
what went wrong??
I tried connecting a 250v 20amp soft serve ice cream machine to a new circuit i just installed in my main breaker box. i ran 2 hots to the outlet screws(1 hot on each screw) and the ground to the ground outlet screw. on the breaker box end, i connected 1 hot to a single 20a breaker and the other hot to another single 20a breaker. the ground wire i connected to the neutral/ground bus.
I took a reading at the outlet and it reads 1 volt...what happened??
thanks
mleee999 is offline   Reply With Quote
Old 12-12-2009, 12:43 PM   #2
Electrician
Rewards Points: 760
You say you used 2 single pole breakers, these two breakers may have ended up on the same phase in the panel.
Your real issue here is the fact you used two single pole breakers. For this application you will need a two pole 20A breaker or your two singles with a tie between the handles.
darren is offline   Reply With Quote
Old 12-12-2009, 12:45 PM   #3
joed's Avatar
Rewards Points: 11,624
You have both breakers on the same pole of the service. As stated you also need a double pole breaker to meet code.
Old 12-12-2009, 12:50 PM   #4
300zx's Avatar
Post
Yes this is what he did.He needs a Double Pole Breaker, OP What type of panel do you have ? any pics?
300zx is offline   Reply With Quote
Old 12-12-2009, 12:52 PM   #5
Also the electricity in commercial/industrial/business buildings is not always the same as in a home!
Look at the label (nameplate) on the machine and see what electricity it requires. What does it say?
For example here is one which says "440 volts 3 phase", which homes do not have...
Billy_Bob is offline   Reply With Quote
Old 12-12-2009, 12:57 PM   #6
what went wrong
It is a ge 200amp box...not sure what model... I stacked the 2 single breakers one on top of each other. It sounds like I have the wrong breakers...I will get a 2 pole and try that....thanks again!!
Old 12-12-2009, 01:00 PM   #7
LOL! no I wont be fooled again buying something that is 3 phase for my house.... the machine is 1ph 60
Old 12-12-2009, 01:03 PM   #8
300zx's Avatar
Post
You need a 2 pole breaker you could try and move one of the breakers up or down one leaving a space in between the 2 and read your voltage see if you have 220 but thats not a fix needs to be done right, Unless its 3 phase like billy bob said.
Old 12-12-2009, 01:06 PM   #9
And what voltage does the nameplate say?
Old 12-12-2009, 01:18 PM   #10
it says 208/230 2wire
Old 12-12-2009, 01:29 PM   #11
Well there may be jumper wires or different connections you would use inside the machine to use 208 or to use 230 as you wish. (Maybe a switch.)
Be sure to read the installation manual so this wiring is configured as it should be.
Or call the manufacturer and ask.
Or post brand/model number here and maybe someone can find the manual/wiring diagram or instruction manual on the internet.
Whatís wrong with my new Business? CNM Design Off Topic 6 09-10-2009 10:07 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Wrong Caulk dwatkins8 Painting 7 08-31-2008 01:27 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 09:13 AM
Drywall,what am I doing wrong? Feangel Painting 4 06-19-2007 09:17 PM
