What Went Wrong - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 10:16 PM   #1
What went wrong
I plugged my new tv into a receptacle in the livingroom, suddenly the lights go out in the bathroom and the hall light doesn't work. I flipped the breaker and still nothing, what are some things i should check?
Oldsparky is offline   Reply With Quote
Old 02-18-2013, 10:20 PM   #2
Rewards Points: 12,818
Nothing should have happened.
Look for a tripped GFI.
Oldsparky (02-18-2013)
Old 02-18-2013, 10:23 PM   #3
I checked the one in the bathroom....should i check for one somewhere else
Old 02-18-2013, 10:38 PM   #4
Missouri Bound's Avatar
Any GFCI's or arc fault breakers in your panel?
Do you want it your way or the right way?
Old 02-18-2013, 10:41 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'd stop wasting your time looking for GFI's. The first thing I would do is take the receptacle apart and look for any loose connections or damage to the receptacle.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
rrolleston (02-19-2013), sirsparksalot (02-20-2013)
Old 02-18-2013, 10:42 PM   #6
Could be anywhere, no one he's going to know how your house was wired.
Outside outlet, in the garage, kitchen are some of the common places.
Old 02-18-2013, 10:46 PM   #7
Unplug it and then reset the breakerand try again if the light come back on. May be a fried power supply in the new tv.
64pvolvo1800 is offline   Reply With Quote
Old 02-19-2013, 08:48 AM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would also take that receptacle apart. If not there I would look around for receptacles on the same circuit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Electrician estimates-how wrong are they allowed to be? eli99 Electrical 22 03-15-2012 10:40 AM
IS this wrong? Romex connector? JeepNick Electrical 27 02-29-2012 11:30 AM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 11:42 PM
Staining project - Did I do something wrong - Need help. family_man Painting 4 11-03-2011 02:10 AM
2 handle shower wrong direction Lisa C Plumbing 7 07-24-2011 10:28 AM
