What Went Wrong? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 03:05 PM   #1
What went wrong?
I have a newly renovated bathroom, light switch not working the vanity light, I replaced the light switch but the breaker will not stay on and I am getting no power, what did I do wrong i replaced the wire exactly like the other switch?
Diyenthusiast is offline   Reply With Quote
Old 06-09-2012, 03:29 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you post a picture of the connections you made or can tell us how you connected the wires we should be able to help you.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-09-2012, 03:31 PM   #3
Rewards Points: 776
double checking wiring. Sounds like you got a wire crossed up.
Could be a shorted romex cable to box. If you use metal boxes and crank down too hard on cable clamp it can pinch into cable and short hot to ground. That will trip breaker.
curiousB is offline   Reply With Quote
Old 06-09-2012, 03:38 PM   #4
With these problems, it's possible you didn't.
Old 06-09-2012, 03:46 PM   #5
rrolleston's Avatar
I have also seen people mix up switch legs and have it black to black and white to white at the light and black and white at switch and it kicks the breaker when the switch is on.
Old 06-10-2012, 03:52 AM   #6
Rewards Points: 324
I had that problem once, replaced a couple of lights and the switch that controlled them; breaker couldn't be reset after I completed the work. Checked and double checked my work, all ok. Local electrician tested & confirmed that the breaker was bad. Just by chance, it'd chosen that moment to fail.
mgp roofing is offline   Reply With Quote
Old 06-10-2012, 06:35 AM   #7
Rewards Points: 2,516
WHich situation do you have? Notice on the right diagram(where power comes into the light fixture location), the incoming hot conductor(black) is wire nutted to a white conductor which provides power to the switch. The switched power from the switch is returned to the light on the black conductor within the cable going to the switch(switch loop)
Notice on the diagram on the left when power enters the light switch location, the wiring is different
What went wrong?-one-sp-switch-one-lite-power-switch.jpg   What went wrong?-switch-loop.jpg
hammerlane is offline   Reply With Quote
Electrician estimates-how wrong are they allowed to be? eli99 Electrical 22 03-15-2012 10:40 AM
IS this wrong? Romex connector? JeepNick Electrical 27 02-29-2012 11:30 AM
Used the wrong nails. ndmeier Remodeling 10 02-18-2012 11:42 PM
Staining project - Did I do something wrong - Need help. family_man Painting 4 11-03-2011 02:10 AM
2 handle shower wrong direction Lisa C Plumbing 7 07-24-2011 10:28 AM
