Old 08-26-2009, 07:21 PM   #1
WaldenL's Avatar
What to use as a subpanel
What makes a panel a "sub" panel? Is it just a normal panel wired as a slave? I know the ground and neutral are not connected in the sub, but run as seperate runs back to the main, it's more a question of what kind of box can I use?
Do I just get a "normal" load center box and wire it downstream of a breaker in the main box? Say it's a 100A box, can I wire it downstream of a 60A breaker? In that case is the 100A box just a switch? As it will never trip as the upstream 60A would trip first.
Also, what's with these 10 space, 20 circuit boxes? Are they assuming tandem breakers? The only problem there is there aren't any tandem GFCI or AFCI breakers, right? Between GFCI and AFCI requirement for bedrooms, bathrooms, kitchens and outdoors how many tandem breakers can you use anymore?
WaldenL is offline   Reply With Quote
Old 08-26-2009, 07:41 PM   #2
Xtreme DIY'r
I used a normal main breaker 100a that is powered by a 60a at the main panel
The main 100a breaker provides a disconnect - detached pool cabana
I have another 100a sub next to the 200a panel - powered by a 100a breaker in main panel
Even with it next to the Main panel I used a main breaker panel
I use a 100a for more room - 20 circuits
With GFCI outlets you could still use tandem breakers
Old 08-26-2009, 07:48 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
I'd say you really have a good handle on this.
Basically correct on all points.
Old 08-26-2009, 10:49 PM   #4
WaldenL's Avatar
True, but one gfci breaker seems cheaper (and simpler to test) than a bunch of gfci outlets, plus then you're protecting stuff other than outlets. Unless there's a reason you can't wire stuff like highhats (for example) downstream of a gfci.
Old 08-26-2009, 10:57 PM   #5
Why would you need multiple GFI receptacles? One at the head of the circuit serves the same purpose as a GFI breaker.
Also, WHY would you want to GFI protect lighting???
Old 08-26-2009, 11:06 PM   #6
Xtreme DIY'r
I have about 12 outside circuits right now protected by $2-3 GFCI outlets instead of $30 (25?) GFCI breakers
Plus the other 5-6 normal GFCI portected circuits in the house
I like the $36-54 cost VS $540 cost
And I'll be adding at least 8 more outside circuits
But that's just me - crazy Christmas decorator
http://www.diychatroom.com/f39/why-i...ircuits-50297/
Old 08-26-2009, 11:22 PM   #7
My License Ain't 4 Sale..
Where are you getting $3 GFCIs?
Old 08-26-2009, 11:25 PM   #8
Xtreme DIY'r
I bought in bulk, I have a bunch that were $3 - Levitron
I also have blank face GFCI's that were about $2 a piece
I think all together I bought over 40
Between the house, garage, basement, pool cabana etc
There were only (3) GFCI's when I moved in
One outside outlet was not protected at all
Old 08-26-2009, 11:26 PM   #9
Wire Chewer
Red Squirrel's Avatar
Yeah no kidding, and I thought 60 bucks for a pack of 3 was a steal.
Old 08-27-2009, 12:31 AM   #10
WaldenL's Avatar
D'Oh... I knew that too... Thanks for reminding me. Cool. Makes life simpler.
Why not? Not going out of my way to do it, but if it's a side effect of wiring downstream of a gfci outlet/breaker no harm, right?
Old 08-27-2009, 12:39 AM   #11
Moderator
Termite's Avatar
No harm in GFCI protecting a light, especially in a bathroom. It certainly isn't a code requirement though, and could be quite a nuisance if the receptacle trips and the lights go out.
Old 08-27-2009, 12:46 AM   #12
Makes it easier to know the GFCI has tripped though...
Old 08-27-2009, 01:12 AM   #13
Moderator
Termite's Avatar
Yeah, much easier to detect than that little click!!!
Old 08-27-2009, 07:30 AM   #14
WaldenL's Avatar
That reminds me, when nwe moved in someone had wired the gfci in the bathroom backwards. The bathroom lightswent off when you tripped it, but thye plug itself stayed hot. Maybe it was just a bad gfci, i ended up replacing it anyway as it was the wrong color.
Old 08-27-2009, 01:41 PM   #15
I was under the impression that a GFCI receptacle had a maximum number of downstream devices it could protect. Five receptacles is in my memory. Right or wrong?
I was also under the impression that the lighting circuit and wall outlet circuit for any room could not be common. i.e. one tripped breaker will kill the outlets or kill the lights, but not both. Right or wrong?
I need to get familiar with the code again. A lot of changes have been adopted in the past 10 years.
MI-Roger is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 10:45 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 10:43 AM
Reverse Polarity at the Subpanel adm060306 Electrical 14 07-09-2007 01:58 PM
