What To Use To Stop Patina & Corrison On Outside Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 09:47 AM   #1
Rewards Points: 6,652
What to use to stop patina & corrison on outside wiring
I was checking the disco for the condenser the other day, noticed that due to the humidity this year here in Il, that the ground & screws on the clamps for the wiring were starting to show corrosion & the ground was starting to patina. I have a di-electric Silicone (Liquid Wrench) spray that I use for stuff, would it work for spraying on the contact surfaces for the pull-out, and the grounds, and other clamping surfaces?
I know that we used to use the Red grease on battery terminals and a spray in the Navy to help protect, wiring in box that were in areas that would be susceptible for sea spray.
Old 09-03-2011, 09:21 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Some of the A/C disconnect switch I have see they get corroded pretty fast and what I do many time is get the nonlox { anti corrosion for alum } and smear on the screw and the conductor itself and also I drill out a small hole bottom of the disconnect switch so the condestion can drain out without any diffuctally.
Some of the cheap A/C pullout's are pretty cheap and they don't really last long I have one not too long ago replace it was only for 1.5 years { northen France } thanks to the salt water moisture and get the plastique verison and that slove it.
I am sure couple other guys will comment almost simauir as I speak but there were few good one that last many years as well.
Merci.
Marc
Old 09-03-2011, 10:07 PM   #3
I was wondering about the nolox, when I installed it last year, but never did. Even when I replaced the GFCI on the side of the garage, no less than six months after I had installed it, the screws looked like we were next to the ocean, and the ground was so patina, that I thought it had been exposed to the air for a couple of decades.
I can never remember equipment so poorly made as it is now, when it comes to disco's and wiring. I know it is about keeping costs down, but do they realize, that cutting corners causes danger of life and property, especially when it comes to electrical equipment. I was thinking about just redoing the disco, and put a Junction box just inside the basement, and run UF through the wall for that short distance, due to it would stand up probably better, than the 10/2 NM, and not have to spray anything to protect the wiring. I may go and get some nolox next week, since U.S. Electric, which is a local electrical supplier is not that far from our house.
Old 09-03-2011, 10:12 PM   #4
Electrical Contractor
kbsparky's Avatar
I prefer to use Ilsco's De-OX. It resembles grease, and is not as gooey as the gray No-Al-OX stuff made by Ideal.
PS: Don't send me any PM's if you refuse to enable responses. General questions will only be answered on the open forum in any case.
-KB
Old 09-03-2011, 10:21 PM   #5
Code05's Avatar
Rewards Points: 1,104
I use the same brand.
Code05 is offline   Reply With Quote
Old 09-03-2011, 10:32 PM   #6
Thank you guys. I am probably going to change out that disco next year, but I may get the De-Ox, to protect the stuff now, especially with that I spent enough so that the wife could have Central Air, and she is not happy if it does not work.
Old 09-03-2011, 10:50 PM   #7
kbsparky's Avatar
Readily available at E.D. Supply
-KB
Old 09-04-2011, 07:01 AM   #8
Too far, but I should be able to get it at the place down the street that is a whole seller also.
Old 09-04-2011, 08:21 PM   #9
Code05's Avatar
Yep. The Easton branch is 3 blocks from my house.
Old 09-05-2011, 10:20 AM   #10
Licensed electrician
Rewards Points: 1,608
So I guess the Walmart and Quiznos are 3 blocks also? How about a Sonic chili dog?
How do I adjust hot water limit stop in single handle shower faucet? ThunderCAT Plumbing 2 03-09-2010 02:13 PM
Hinge Pin Door Stop exterior dws General DIY Discussions 5 02-17-2009 09:58 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
