Old 05-31-2008, 01:48 PM   #1
What type of wire to connect motion sensor to light?
Folks,
I want to install a motion sensor with an exterior light. The motion senor and light were purchased separately so they're not wired together. The place I want to position the motion sensor - a location about two feet away from the light - exceeds the lengths of the thin gauge wires that came with the light and motion sensor.
Question: what type of wiring should I purchase to connect the motion sensor to the light? Once I have the correct wiring, should I make pigtail connections between the two devices? If it helps, I'm going to be powering the devices with a 12-2 gauge wire/20 amp circuit.
Nick
beezlebub03 is offline   Reply With Quote
Old 05-31-2008, 02:16 PM   #2
electrical contractor
I would connect the light and motion sensor with a piece of conduit and pull in 12 awg thhw wire, I know the wire on the light and sensor are likely 14 awg, but if I were using a 20 amp breaker I would use 12 awg wire for anything I put in.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Tags
exterior light, motion sensor, wiring
Dual sensor Dual head motion light? sandyman720 Electrical 1 09-26-2007 07:40 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 07:54 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
